Author Topic: removing oil filter bolt (w/o power tools)  (Read 8069 times)
Offline UnCrash
  • Pass
    • My Blog
Re: removing oil filter bolt (w/o power tools)
« Reply #25 on: September 20, 2008, 07:23:37 PM »
Quote from: UnCrash on Today at 11:57:36 am
My first oil change on my 750......
I resorted to power tools in the end.
A little extreme?   I just dremeled the head of and pulled the housing off over then put vise grips on the bolt. No damage to the filter housing. Replaced it with one of the 17mm ones.
I was doing a complete teardown to frame and had help waiting around to pull the motor.
I started with the patient route but it was frozen solid, and I was wasting time.  Plus I have a spare housing and new bolt in the garage.
This is where impatience, powertools, and backup spare parts leads you.
Offline Accolay
« Reply #26 on: September 20, 2008, 08:12:57 PM »
I couldn't get mine off either. I went to Home Depot and got a 3 ft with 1in diameter pipe from the plumbing section that fit over my ratchet handle and with a lot of swearing it came right off.
I had to order another bolt for it since the head on this one was all messed up. Next oil change it will be installed.
1977 CB550F
Offline jason teamshralp
« Reply #27 on: September 21, 2008, 12:10:23 AM »
everyone remember with these new 17mm bolts you have more of a chance to over do it. Honda probably made the original a 12mm for that same reason.
also try the engine warm to get the bolt off, but remember that will make the head of the bolt softer.
This is my favorite method ever...
Offline Soos
« Reply #28 on: September 21, 2008, 12:13:14 AM »
HAHAHAHHAHAHAA... :o ;D ;D ;D ;D ;D
You have a good selection of hammers as well dontcha?
It is not the road, but the destination that matters.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Johnie
« Reply #29 on: September 21, 2008, 06:31:40 AM »
I am sure as you were cutting that filter housing off you had a great deal of satisfaction for sure... ;D :D ;)
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
matt400f
« Reply #30 on: September 23, 2008, 10:46:01 AM »
I haven't gotten the bolt off yet... more problems with the bike running rich right now - BUT I'm going to try this weekend some more!
Offline mark
« Reply #31 on: September 23, 2008, 11:07:51 AM »
I like it. I'll have to remember that one.......
... In case welding a big nut on there and zapping it with the impact doesn't work. I have also found that a professional-quality tool (i.e. Snap-On) can often remove a battered bolt when others fail.
Installation tip: It's pretty hard to overtighten the bolt with the toolkit wrench.
Happy trails.
F you mark...... F you.
Offline WFO
  • Will work for powerbands
« Reply #32 on: September 23, 2008, 12:23:47 PM »
I guess the next step was dynamite  ;D
82 cb650 sc nighthawk - 78 kz 650 b
Offline mystic_1
  • 1970 CB750K
« Reply #33 on: September 23, 2008, 04:02:21 PM »
Nah, don't be silly.
Detcord would be the next step :D
mystic_1
- John Augustus Shedd
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #34 on: September 23, 2008, 04:11:28 PM »
wOw!  I can't believe on how hard some of these oil bolts looked to remove - maybe the APO used that old hillbilly adage of "torque 'er down 'till it strips and then back 'er off, a quarter turn" to come up with torque values. . . lol
Maybe try one of these? (that's a 26mm acorn!)   :o
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline Drewery
« Reply #35 on: October 01, 2008, 04:22:25 PM »
I remember having the same problem (once!) with a 17 mil bolt and the mechanic who sawed it off for me told me, the reason Honda used a 12 mil was so that people could NOT reef them on too hard. He said he was constanly cutting off 17 mils so easy, tiger.
72' CB500K1
69' Triumph GT6 plus
« Reply #36 on: October 01, 2008, 10:54:11 PM »
mystic_1
Yeah, I reckon I'd use a CE primer, that'll crack the case of an M26 grenade OK, I think detcord's probably better for removing carbs from 35 year old rubbers, or loosening rusty header bolts? ;D
Offline goon 1492
  • Sucka Repellant
« Reply #37 on: October 02, 2008, 09:16:33 AM »
mystic_1
Ya better be quick on yer feet thought or you'll be like those cats tryin to set off 4,5,or 10inch mortars on the fourth of july blowin their faces off cause they used a lighter instead of electric firing, I would rather use blasting cap, at least with one end not capped you could use it as a torch :P or cap it and away we go  ;D ;D ;D and then use the extrsa to blow up a couple of tree stumps. 8) 8)
Offline Johnie
« Reply #38 on: October 02, 2008, 09:31:04 AM »
Anyone ever put anti-seeze on the filter bolt threads?
Oshkosh, WI  USA
Offline mystic_1
  • 1970 CB750K
« Reply #39 on: October 02, 2008, 10:12:39 AM »
I never have but it's probably not a bad idea.  However the threads sit in oil full-time so I'd think it'd be better to put the anti-sieze on the bolt head flange where it contacts the filter housing.  Oh, and don't over-tighten the bolt  ;D
mystic_1
Offline WFO
« Reply #40 on: October 02, 2008, 01:27:44 PM »
mystic_1
Ya you would think just snugging it up to flatten out that oring should be enough anymore than that is a waste of time and this thread proves it. ;D
« Reply #41 on: October 03, 2008, 04:58:09 AM »
I wouldn't use anti-sieze anywhere inside an engine, as the hot oil would probably wash it out, and it may end up causing clutch slip. Cheers, Terry. ;D
Offline goon 1492
  • Sucka Repellant
« Reply #42 on: October 03, 2008, 06:32:25 AM »
Terry that thing in your avatar made me pee alittle  :'( :-* ;D
troppo
« Reply #43 on: October 03, 2008, 06:34:39 AM »
Yeah, anything with four ears AND a moustache just isnt natural ???
Offline snipcod
« Reply #44 on: October 03, 2008, 07:09:18 AM »
Man I know how ya feel, I just ween through that about a week ago.  What I did was to grind it flat then make a cross and use a cold chisel with a hammer.
http://forums.sohc4.net/index.php?topic=41185.0
It takes an idiot to do cool things, thats why it's cool
« Reply #45 on: October 03, 2008, 05:49:54 PM »
Don't tell the wife mate, she friggin' loves me! ;D
