Author Topic: Syncing CB650 Carbs?  (Read 1020 times)
Logite
« on: September 19, 2008, 09:55:44 PM »
I have my manometer set up, but I'm somewhat confused on how to hook it up.
I've got all 3 hoses hooked up, but the last hose I can't seem to figure out where to hook it up to. Second cylinder's vent hole is used by the accelerator pump. Anybody know how I hook up my 4th tube to the 2nd carburetor?
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Syncing CB650 Carbs?
« Reply #1 on: September 19, 2008, 10:27:44 PM »
What year CB650?  On my '79 engine, all four manifold vacuum ports are available.  And, why are you referring to the "vent hole"?  Can you take a pic?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Logite
« Reply #2 on: September 19, 2008, 10:46:07 PM »
'82. I mean vacuum port. Pretty new stuff to me. All 4 are available but the second port has a connector from the accelerator pump screwed into it. Any ideas?
Offline Soos
« Reply #3 on: September 19, 2008, 11:31:50 PM »
No...that 1 port there goes to your vacuum operated petcock.
just (carefully!) unscrew it, and put your 4th lead there.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
