Test drove a 77GL1000 today, speedo/odo reads 28k+. The feller says it's been in the family since new.
The good...Has new throttle cables, timing belts, electronic ignition/wires/plugs, battery and tires.
The bad...first stop I made on a long test drive today (160 miles), it wouldn't start. Luckily he had showed me where the kicker was, and I found where to insert it. Ok, a pain, but doable. Horn occasionally does not work, gas guage sometimes does not work, neutral light is on when in gear.
Cost? $1200.
My question...when going up some good hills here in SE MN, it would bog down, not pull the hill, holding the same speed. Often dropping speed. Approaching hill at 55-60, 5th gear. (about 4k rpm) Is this thing geared high, so it is smooth and quiet on the interstate? When I finally got to one, got it to 70, it sure seemed nice and smooth, but most hills on the interstate are not as steep as the secondary roads where it is fun to ride. I did kick it down a gear, and that made a lot of difference, so I am wondering if it is gearing and learning how to ride, or if the bike really has 128k and is tired. I was riding in the middle of 2 new 750 vtwins, they pulled the hills with no apparent problem, no downshift required. (My CB750A will pull the hills and gain speed, so far on any hill that I've ridden.)
The engine seems strong and certainly willing to haul my fat butt around, seems to develop the power over 4k rpms. Maybe I've answered my own question here. Any comments? Any idea of what it is worth? Paint is fair, pipes are pretty good.
Thanks
