Author Topic: $125 for used forks?  (Read 1785 times)
Offline MJL
  • Don't listen to me, I'm no
« on: September 22, 2008, 01:03:11 PM »
I either need another set of forks or new tubes and springs. I found a local guy with a set of used '72 750 forks, he wants $125.    If I bought new parts through Cycle X I'd be looking at at least twice as much.   So, used forks, $125, deal or no deal?
Offline ColinMc
  • There aint no pickle like a super pickle...
Re: $125 for used forks?
« Reply #1 on: September 22, 2008, 02:12:47 PM »
I have a set of used forks off my cb750k6...not sure if they will fit but i don't want nearly that much for them! lol. Still sorting out pics and info for a few other people on other parts but the thread is in the Parts For Sale section.
EDIT: These forks will most certainly need fresh seals and oil btw. But I only want 40 and they are in decent shape.
« Last Edit: September 22, 2008, 02:19:15 PM by ColinMc »
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline WFO
  • Will work for powerbands
« Reply #2 on: September 22, 2008, 02:15:03 PM »
You might end up rebuilding the $125 forks anyways or if you know they are good just make one good set of forks out of the two or the $125 forks will work perfect or fix the forks you have now right the first time and avoid a total fork removal ( it's your call really)
82 cb650 sc nighthawk - 78 kz 650 b
Offline MJL
« Reply #3 on: September 22, 2008, 03:21:08 PM »
My forks are very stiff. I measured the springs and they are about a quarter inch short. I have tried changing the fork oil but it didn't help much if any.  I do know that the seal on the left fork is bad, and there is aspot on the tube where the chrome is worn off.  So, new tubes plus springs plus seals, or just another set of forks.
The bike is a 73 750.
Offline MJL
« Reply #4 on: September 22, 2008, 03:30:40 PM »
I'll post there then.
Anyone know if the k6 forks will work on a k3?
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #5 on: September 22, 2008, 03:49:57 PM »
Assuming that by "forks" you mean both entire upper and lower assembies.
If so...
72 forks will not work on a K3
Only K3 - K5 will work.
K6-K8 will not work
If you want to mix and match that's a different story.
Offline bert96
  • past ride
« Reply #6 on: September 22, 2008, 04:54:20 PM »
I have a k7 fork on my k4 without any problem.
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline MJL
« Reply #7 on: September 22, 2008, 05:25:19 PM »
If so...
K6-K8 will not work
What keeps one from working on the other?
Hmm, rebuild time then?  Well then, if my tubes are bent, (if) could there be scoring inside that would prevent me from just installing new tubes?  This bike rides like a rock and after I smooth out the front I'll stick some new shocks on the rear.
Offline Gregorymoto
  • SOHC Aficionado
« Reply #8 on: September 22, 2008, 06:06:40 PM »
I've never had issue swiping out different k front ends with the different years. The F tree has little wider span from tube to tube other than that they are all the same.
Lets start hear, what is wrong with the set up you have now. If you need new tubs last time i bought a set from Forking by Frank i spent around 130 but that was in the mid 90's.
Yep, i have issues with this sort of stuff.
Offline Gregorymoto
  • SOHC Aficionado
« Reply #9 on: September 22, 2008, 06:14:18 PM »
ok i just looked over the post, i would just rebuild what you have, you dont know what you are buying.
Get some progressive springs and new oil seals. Test that out.
I bought my springs from Dynoman i think it cost 65.00 or something around there.
I think the fork seals where 20.00
The springs where a little soft for me so i made plugs to get the spring load where i wanted it.
Offline ColinMc
« Reply #10 on: September 22, 2008, 06:23:09 PM »
I thought the forks themselves were identical from k2-k6? Calipers, brake lines, springs, all that stuff are the same part numbers...
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #11 on: September 22, 2008, 06:49:12 PM »
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Gregorymoto
  • SOHC Aficionado
« Reply #12 on: September 22, 2008, 06:51:55 PM »
Ya i have never had issue swapping out front ends, not sure what his info is based on.
Offline Tower
« Reply #13 on: September 22, 2008, 08:51:21 PM »
It depends on what you mean as "swappable".  For example there's nothing wrong with swapping out the entire fork from K7 onto a K3...as long as you don't mind also swapping the fender.  You can swap one tube for another and you can swap out one set of springs for another as long as you don't mind cutting them or living with the lowered/raised swap (depending on which year is swapped).  You can even put incompatible lower assemblies together as long as you don't mind drilling holes in the lowers..etc..
KingCustomCycles.com
« Reply #14 on: September 23, 2008, 11:41:54 AM »
Goldwing forks and trees are a drop-in to the steering head...Just wanted to muddy the waters.... :D
Offline Tower
« Reply #15 on: September 23, 2008, 01:35:14 PM »
Good prompt, KCC.com.  Maybe I can muddy  the waters some more also... :D
Any K fork pipe and many aftermarket tubes will bolt up into any K triple tree - but that's not the whole picture.
For example, If a K0 to early K2 pipe is bolted in (there are two varieties), then the bottom covers have to come with, because the oil locks are not compatible with other years, and fenders come with because the lower's bolt pattern of other years is not compatible, and the seals come with because the fork piston arrangement is not compatible with other years, and the springs because the comp pipe is not compatible.
Bolt in a late K2 - K6 pipe (there are three varieties) or K7/K8 pipe and a similar but different decision tree falls into place.  If you follow the decision tree then you have a "workable" swap.
The combinations and permutations of seals, rings, pipes, ears, fenders etc. that work are many, but so are the combinations that don't work.
Also, there are combinations that work, but with slight mods.  e.g. K2 pipe matched to K3 - K8 lower covers would probably work if you alter the oil lock, fabricate a short comp pipe and possibly a rebound spring, and swap oil seals and oil cushions.
Offline Gregorymoto
  • SOHC Aficionado
« Reply #16 on: September 23, 2008, 02:18:33 PM »
yep did once as well.
