Author Topic: Converting CB550 to LED... question  (Read 30142 times)
Offline painteddigital
    • Portfolio
Re: Converting CB550 to LED... question
« Reply #25 on: June 18, 2013, 01:55:16 AM »
Application   SuperBright LED
Taillight   1157-RLX3
Oil Light   BA9S-R
Inst Lights   BA9S-W
Neut light   BA9S-G
high beam indicator   BA9S-B
turn signal indicator   BA9S-A
Front turn signal   68-A9
Rear turn signal    67-A15
Sorry to open up a super-old thread, but this one seems like the best resource I've come across. I grabbed the 68-A9-WV that you recommended, but on my bike they won't come on at all, even when I turn on the flasher. The stock incandescents work fine so I'm left scratching my head. Perhaps the wide angle or the polarity is impacting them, but I thought someone may have had similar experience.
Also, I'm really curious about the right angle 1157 bulbs that SuperBrightLEDS has available now
https://www.superbrightleds.com/moreinfo/tail-brake-turn/1157-led-bulb-dual-intensity-2-watt-adjustable-right-angle/816/
Does anyone have any experience with this bulb? Does this look like it'd fit the front running/turn signals?
Offline Kenzo1979
« Reply #26 on: June 18, 2013, 04:56:42 AM »
Here's what I use from superbrightleds.com :
Front Blinkers:  1157-x18-T  (Amber)
Rear Blinkers:  1156-x18-T  (Amber)
Tail Light:  1157-x45-T  (Red)
Instrumentation:  Ba9S-WHP (Cool white)
Blinker Relay:  LF1-S-PIN
*You could probably use the "CBT" models over "T"  for blinkers and save about $40, but I would still go with the 45-T for the tail light.  If you're not using the fronts as running lights just get 1156's for all 4.  The relay for some reason you need to reverse the black and grey wires if memory serves correct.  These are bright and look great.  I have the same setup on all 3 of my bikes.  This place is also good for getting replacement socket bases.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline sixthwisconsin
« Reply #27 on: June 18, 2013, 10:59:06 AM »
I have converted every bulb on my 550 to LED including the headlight. The small bulbs have been covered well so I will not go into that but here is a link to the headlight I am using. This is not exactly like the one I have but an updated model. I will say that it is incredibly bright so don't let anyone tell you otherwise. One drawback, its expensive! But so was everything else I did on the bike!
http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=92025&langId=-1
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #28 on: June 22, 2013, 12:42:04 PM »
Cool.  That headlight uses around 20 to 24 watts of power.  That's about 1/3 of a standard bulb.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #29 on: June 22, 2013, 03:04:10 PM »
Wow.....that's a pricey headlight.  $290.00 on sale regular price $325.00.  It would be nice and is certainly unique but way out of my budget!
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline jonclegg
« Reply #30 on: February 25, 2017, 06:28:42 PM »
Just wanted to update this thread as I just went down this rate hole.
The cheapest easiest solution is this product:
https://www.amazon.com/gp/product/B01C1AOSVS/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
It's a LED bulb replacement, it works fine, gives out slightly better light than OEM.
The 2nd way to go is a full replacement, you can find those for about $60 like this one.
https://www.amazon.com/gp/product/B01DP9EQQG/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
This also fits in fine, but you need to take apart the headlight assembly, which takes about 5-10 minutes.
