Well what i'm worried about, is that the tires do mount and hold air, but i'm not sure these rims are designed for anything at speed like that...isn't there a chance things could go bad once things are moving, especially at higher speeds say in a corner? The original Honda MB5 rims can have normal tires mounted without tubes and they'll hold air, but they most certainly are for tubed tires so I would never risk it.
So in the end, do I go with what they originally used? I know tubeless tires were available in 1986...so why would Honda use tubes in the tires if they didn't need them? So i wouldn't be worried about the tube pushing the tires off the rims, or Honda wouldn't have used them in the first place...
I'm not trying to be argumentative, just genuinely curious...
