Author Topic: CB550/4 Carbs - Main jet problem  (Read 1150 times)
grapppa
« on: September 16, 2005, 05:41:25 AM »
I cleaned my carbs with Berkibile 2+2 and found that the cast aluminum?magnesium will be eaten away at the point where the main jet mounts also on the posts supporting the float.  Is there a way to restore this lost metal.  I am thinking of using a gas resistant liquid metal that hardens.  Any thoughts ?
Offline Gordon
  • 750K1, 550K2
Re: CB550/4 Carbs - Main jet problem
« Reply #1 on: September 16, 2005, 06:06:01 AM »
You'd probably be much better off just buying another used set of carbs off eBay.
