Author Topic: oil pump info needed  (Read 1360 times)
« on: September 16, 2005, 04:01:04 PM »
In the next few weeks we will be starting to build next years race motor.
Although we have all the specs for wear in the oil pump, we have not started in this department yet, and I am wondering what we may find.
The reason I ask this is I have not seen on here anyone with oil pump problems, has nobody had problems with oil pumps on CB750s ?
Sam.
Offline 750deepsouth
Re: oil pump info needed
« Reply #1 on: September 16, 2005, 04:11:22 PM »
Sam,
I've never had, or heard of people having, problems.
We rebuilt our pump back to specs on my motor.
Andy
« Reply #2 on: September 16, 2005, 04:28:13 PM »
Andy, why did you rebuild your pump if it did'nt have a problem, or are you like me wanting to be on the safe side after spending several grand on the thing.?
Sam.
Offline kghost
« Reply #3 on: September 16, 2005, 05:12:01 PM »
I haven't had problems per say,
I replaced one I thought was runnin kinda low.
There was some scoring internal to the scavage side........
Any one know where to get the internals?
Stranger in a strange land
« Reply #4 on: September 17, 2005, 01:56:07 PM »
Hey Ghosty,
Andy in NZ must know as he has replaced his, have not checked ours out yet, so don't know if anything needs doin.
Sam.
« Reply #5 on: September 17, 2005, 04:32:07 PM »
Sam,
I should not have used the word 'Rebuild' .
We dismantled the pump, made sure all clearances were within tolerances, they were, and reassembled it.
« Reply #6 on: September 17, 2005, 04:39:18 PM »
I think David Silver has parts, but not to sure what he has.
« Reply #7 on: September 17, 2005, 04:39:34 PM »
Sam
 It's a good idea to check the rotors. I haven't seen them"wear out" BUT I have seen gouges, nicks, scrapes etc which can compromise pil pressure.
« Reply #8 on: September 17, 2005, 04:55:40 PM »
Evening Mike, hows things.
Ghosty mentioned some scoring in the roter body, probably replaced it with second hand pump, as he asked where to get parts.
Should be pulling ours apart in the next few weeks prior to the rebuild of motor next month.
The last meeting of the season in the morning at Santa Pod, about 145 miles away.
Chris is hopeing to break the class course record if the weather holds out.
Regards Sam.
« Reply #9 on: September 17, 2005, 05:02:42 PM »
Things are well with me Sam- very busy though. Good luck at the meet sir. ;)
« Reply #10 on: September 17, 2005, 05:17:05 PM »
Thanks Mike,
I thought you had been busy as I have not seen you on line much.
Sam.
