Author Topic: Got a blast cab today...  (Read 2028 times)
Offline Burke
« on: September 27, 2008, 12:15:17 PM »
I bought a little bench top blast cab today and got more done in 2 hours on my project then in the past 2 weeks.  ;D
This should really help me pick up the pace.
TSC has them on sale for $99.
I bought mine from a smaller privatley owned place. It cost me $19.00 more, but they are good peolpe and will stand by ya if something goes wrong with it.
Off to blast..
Offline walkingchaos
  • Im new, be gental
    • Clear Photography (my business)
Re: Got a blast cab today...
« Reply #1 on: September 27, 2008, 01:10:23 PM »
do you mean sand blasting ?   How does that work at home, do you have an attachment for your home air compressor ?
73' CB750 Cafe Racer
76' CB750 Frame . . . possible project
fuzzybutt
« Reply #2 on: September 27, 2008, 02:05:26 PM »
tsc?
Offline youngerthanmybike
« Reply #3 on: September 27, 2008, 02:22:33 PM »
I'm pretty sure that's Tractor Supply Company, but not 100%...
Offline Burke
« Reply #4 on: September 27, 2008, 03:04:44 PM »
Yep, Tractor Supply Company.
But I bought mine at a place called Sam & Jakes.
Instead of "Sand" it uses Glass beads. Really fine.
It just hooks up to your compressor like any other air tool. It does have an attachment so you can hook up a little vacuum to clea the dust.  But for what I use it for i'm not in there that long so I just let it settle for a few minutes before I remove the parts.
fuzzybutt
« Reply #5 on: September 27, 2008, 08:27:52 PM »
how many psi at what scfm does it require?
Offline Burke
« Reply #6 on: September 28, 2008, 06:54:38 AM »
80 psi
SSCR
« Reply #7 on: September 28, 2008, 08:10:36 AM »
pics?
Offline Burke
« Reply #8 on: September 28, 2008, 07:41:44 PM »
Offline void909
« Reply #9 on: September 28, 2008, 07:52:59 PM »
Is It all inclusive besides the air supply?
knock with no answer
Offline Burke
« Reply #10 on: September 28, 2008, 08:18:19 PM »
Yes. gun, nozzels, hoses, and light. I did have to buy the abrasive and the air chuck connector. These cabs may work with just plain sand, but it states clearly that sand (silica) is "bad", and it reccomends the glass bead abrasive.
It does have some "blow by" from the corners, but nothing major.
Im happy with it so far.
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
« Reply #11 on: September 28, 2008, 08:49:26 PM »
Yeah blasting makes quick work of cleaning things up doesn't it?
I picked up this up a couple of months ago http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93608
It's listed at $249, but if you wait they put it on sale every other month for $199.  Harbor freight also has the bench top models.
It does require a larger compressor.  I have one that pumps out about 13.2 cfm at 90 psi.  It keeps up ok, but if you blast continuosly, you give the compressor a mild workout.  And you can connect a shop vac to the dust port.  Just get the upgraded filter for the shop vac.  There is a device called the cyclone (search for dust cyclone) on ebay, that helps with dust collection even more.
You can use soda in the cabinets as well.  You can pick up soda at a pool store.  Or Sam's club.  The other media I use is coal slag (black beauty, black magnum are it's trade names).  The soda is much gentler and is for basic cleaning.  The coal etches the metal.  Soda get's used on carbs and metal you would polish or don't want to remove any metal from.  Coal is used on more damaged material or material that is going to be finished in a another way.
It's a slippery slope though.  Once you have the blaster, it's just another trip to harbor freight to pick up a powder coating unit.  Next thing you know, you got another $500-$600 on your cc.
Here are some brackets I practiced on.
Battery tray for a 79? mazda.  Somewhere I have a middle picture of the tray blasted.  I'll try and dig it out.
Got it.  And if you live in a humid climated, you gotta either powder coat\paint the part right after blasting or use a phosphate coating or primer.  After blasting metal flash rusts extremely quickly.  I swear during August, the front side rusting while I was still blasting the other side!!!
After powder coating the tray flat black.
« Last Edit: September 28, 2008, 08:57:42 PM by mcuozzo »
Offline Burke
« Reply #12 on: September 28, 2008, 08:57:05 PM »
Funny you mentioned the powder coater.Thats the next thing I was looking at. It only makes sense right ;). Clean then coat.
Our garages will be  one stop shop before we're done ;D.
Offline mcuozzo
« Reply #13 on: September 28, 2008, 09:02:22 PM »
Too true.
Thing is the Powder Coating thing is addictive.  I wast my time pc'ing stuff instead of trying to rebuild the bike!
All you wanted to know about pc'ing is at this place...http://www.caswellplating.com/powder/index.html
Check out the forums as well.  Whatever you do, don't go to the polishing forums\products.  Talk about a slippery slope.
And for powder coating check out Eastwood, Columbia coatings, powder by the pound.  There are some others that can be found on the caswell site (although caswell sells pretty good powder).  You just missed out on a 2-for-1 sale at caswell.  I picked up a bunch of it!!!
Offline dagersh
    • Photos
« Reply #14 on: May 28, 2009, 11:59:25 AM »
Mcuozzo,
Do you have to convert anything when switching between the Soda to slag?  I know Eastwood sells a Soda Conversion Piece, but I think its only for the portable units.  What else would I need to blast with Soda using the HF unit you have?
Thanks!
Gersh
Got my answer here:
Changing to a smaller nozzle might help, but I didn't and it works fine.  I literally just dump out the coal slag, blow the remainder out of the unit than fill with soda and vice versa.  I don't change a darn thing but the media.  I'm lazy.
But...You gotta be more careful going from coal to soda.  Leave enough coal (or other hard abrasive) and you might ruin a more delicate piece.  I am thorough about getting all of one media out before putting in the other.  Don't forget to blow out your suction line and the gun body.  Some media likes to hang out in there.
« Last Edit: May 28, 2009, 12:24:51 PM by dagersh »
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline silver fox
« Reply #15 on: May 28, 2009, 01:01:53 PM »
Hey Burke
Sod the cabinet, have you got a link from the site you found your avatar :P
Offline silver fox
« Reply #16 on: May 29, 2009, 11:53:21 PM »
Bump ???
Offline tramp
« Reply #17 on: May 30, 2009, 04:07:56 AM »
something to look into
think i'll go to harbor freight today
1974 750k
Offline Burke
« Reply #18 on: May 30, 2009, 09:03:16 AM »
Hey Burke
That pic is from Deviant Nation.
i found the link through "Inked" Magazine.
Plus I have a thing for hot chicks with tattoos.
  • Be careful you might get a
« Reply #19 on: May 31, 2009, 08:22:23 AM »
This thread is killing my bank account by the second.
