Author Topic: F series Rear brake assembly pics ?  (Read 2613 times)
Offline walkingchaos
  • Im new, be gental
    • Clear Photography (my business)
« on: September 27, 2008, 06:46:15 PM »
hey guys,
     So  i think im going to try and do the conversion to a rear disk brake since im swapping over to the F frame. I have found a 16" rear wheel that i think i can use to do the conversion. Does anyone have an F series bike they could send me detailed pictures of so i can see what im getting into ? Thanks guys.
73' CB750 Cafe Racer
76' CB750 Frame . . . possible project
Offline kghost
Re: F series Rear brake assembly pics ?
« Reply #1 on: September 27, 2008, 06:52:51 PM »
I have a K frame with F front and rear....I think theres a pic in my gallery.....
Spoke F or comstar F?
Stranger in a strange land
  • Im new, be gental
« Reply #2 on: September 27, 2008, 07:18:29 PM »
the wheel i found for the rear i believe is a spoke F. its a 16" wheel
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #3 on: September 27, 2008, 08:31:33 PM »
Besides the wheel, you need the swingarm as well, or you'll (probably) need to weld in a mount for the brake stay.
I did nearly the same thing on my bike-  the PO had a k rear on an F frame and I put everything back to stock.  I went the route of buying everything at once (wheel, arm, caliper/master, pedal) and just swapping it out.
What exactly do you want pictures of?
spwg
  • Im new, be gental
« Reply #4 on: September 28, 2008, 10:25:44 AM »
right now im just trying to judge whats going to be the best route. Im going to use the F frame. Im trying to figure if i should use the K wheel/swing arm/drum brake, and modify the frame to accept the pedal. Or if i should find and buy all the F frame stuff to do a rear disk conversion.
Offline Shenanigans
  • Right turn?
« Reply #5 on: September 28, 2008, 01:22:10 PM »
I am not trying to derail, but if a 750F swing arm will fit into a 750K frame, and a 750K frame swing arm will fit into a 550, why cant I throw a 750F rear swing arm in my 550? It would be a lot easier than machining and welding the 550 swingarm for a rear disk and I could keep it looking more period correct. (The drum brake is sufficient, but its not sufficiently cool...)
  • Im new, be gental
« Reply #6 on: September 28, 2008, 01:48:10 PM »
hehe i think it would work but you def dont want to take my word for it here :)  Im still trying to figure out if my F code frame with a K code arm/brake will work :)
Offline Shenanigans
  • Right turn?
« Reply #7 on: September 28, 2008, 02:00:55 PM »
I have see people claim it but nothing really solid, if it is true I am suprised that no one has done it yet. I remember people saying that the 750's swing arm would fit on the 550 but that is was slightly shorter in lenght or something.
  • I'm not really a
  • 1976 750 F
« Reply #8 on: September 28, 2008, 06:28:37 PM »
Well, I know for sure that you can put a 750k drum/swingarm on the 750f (at least on a 76).  I'm pretty sure that no frame modification is necessary, but a brake lever height adjustment stop would be nice.  If you just slap it on there it hits the footpeg for a stop (which worked fine, but not the best).
spwg
  • Im new, be gental
« Reply #9 on: September 28, 2008, 06:33:01 PM »
thank you, that is def what i wanted to hear. how did you attach the K brake pedal on the F frame?
  • I'm not really a
  • 1976 750 F
« Reply #10 on: September 28, 2008, 06:44:51 PM »
I can't tell you what i did, just what I undid.  I pulled off all the k stuff and put on the F rear end.  both brake pedals went in the same.  Have you studied the parts diagrams?  That'll give you a pretty good idea what's going on for each bike.  I think I still have the whole pedal/arm and aluminum mount sitting on my parts shelf.  I can send a picture for you to compare or send the whole thing your direction.  It's just cluttering up my already cluttered life.
http://www.cmsnl.com/honda-cb750f-750-super-sport-76-us_model490/partslist/F++09.html
  • Im new, be gental
« Reply #11 on: September 28, 2008, 06:48:29 PM »
oh man that would be a huge help. If you feel like unloading that stuff id be alot closer to sorting out my brake issue :) Ill drop ya  a PM   THANK YOU!
