Author Topic: VF500 Honda Carb Air Tubes  (Read 2129 times)
redrocket
« on: September 28, 2008, 07:34:22 AM »
               I'm reassembling a 1986 VF500F Honda Interceptor. The carbs had been removed from the engine when I bought the bike so I'm reinstalling them. After cleaning the carbs I'm installing them. The air tubes that interconnect between the four carbs have a rubber hose coming off to the rear but I don't see where they connect to anything. This is not the California model and does not use a fuel pump or evap system.What is the function of the air tubes and where do they connect? Thanks for your input.
Redrocket
Re: VF500 Honda Carb Air Tubes
« Reply #1 on: September 28, 2008, 08:55:56 AM »
No idea as its a v4 not an sohc4
KingCustomCycles.com
« Reply #2 on: September 28, 2008, 09:20:05 AM »
Here you go my young lost lad:
http://v4hondabbs.com/index.php?PHPSESSID=cacff3f3b8b1baa1b5647d4fd2b61574;
Those are bowl vents and they do not connect to anything unless there is a fitting loose somewhere.  They have to have "atmospheric" pressure I am a closet V4 mechanic at night when no one is around and my wife is sleeping shhhh!
« Last Edit: September 28, 2008, 09:22:08 AM by KingCustomCycles.com »
redrocket
« Reply #3 on: September 28, 2008, 10:14:16 AM »
           Thanks for answering the V4 question. Since I couldnt get a answer on the VF site I looked for a site with real activity thinking someone could help. Thanks for the answer about being ope to the atmosphere.
Redrocket
« Reply #4 on: September 28, 2008, 02:13:53 PM »
 ;) not a problem, I torture myself with the occasional V4 custom.
« Reply #5 on: September 28, 2008, 10:30:27 PM »
Sorry for the "short" answer but having spent 6 hours trying to sync a set of carbs on a v4 with vac gauges and eventualy ripping them off and using a drill bit i swore i would never get within hitting distance of one again!!
