Author Topic: Should a K3 need needles raised to full height (rich)??  (Read 1135 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: September 28, 2008, 03:42:09 PM »
My K3 has symptoms of running lean in the mid range so I opened the carbs to check the needles. I found the needle clips on the 2nd from the bottom slot - i.e. one slot above max fuel flow.
Seems odd to me that a mostly stock K3 should need the needles raised up to max height.
Should I just put the clip on the bottom slot & not worry about it or should I look for something else?
CB750 K3
Stock air box, new Emgo filter.
Carb boots good and tight
4 into 2 pipes (like Mac)
5 ohm Dyno coils
Just had a full tune up, strobe timed, points dressed, valves checked...
White plugs, bluing pipes, popping, engine searches while at mid RPMs /  constant throttle, surges when RPMs hit about 5500 and 3/4 throttle...
« Last Edit: September 28, 2008, 03:45:21 PM by grumpy »
Offline joeb
Re: Should a K3 need needles raised to full height (rich)??
« Reply #1 on: September 28, 2008, 03:56:56 PM »
You may want to check your jet sizes.  And a good cleaning of your carbs may be in order. Also check for vacum leaks.
Offline grumpy
« Reply #2 on: September 28, 2008, 04:59:15 PM »
jets were OK, cleaned them anyway, needles looked OK.
only real problem was one float was way out of adjustment.
I was "hoping" to find crud in the needle jets - that way at least I'd know what the problem was.
WHALEMAN
« Reply #3 on: September 28, 2008, 06:11:40 PM »
I will argue that anyone running original 35 year old carb to engine rubber manifolds has some problem. Changing mine was the best thing I have done in 10 years. I thought mine were fine. The change is so small each year as to hardly notice. No, You should not have to raise your needles all the way. Dan
WHALEMAN
« Reply #4 on: September 28, 2008, 06:15:30 PM »
I also recommend the carb manifold clamps that carpy sells. They are good quality and get much tighter than stock. Dan
Offline grumpy
« Reply #5 on: September 28, 2008, 06:30:59 PM »
HA!!!
Got em on there already!!!
manifolds seem to seal fine, no change in RPMs when cleaner is sprayed around edges - they're not original - not sure how old, tho...
« Last Edit: September 28, 2008, 06:32:34 PM by grumpy »
