Author Topic: Primary chains  (Read 857 times)
Offline voxonda
Primary chains
« on: October 01, 2008, 04:41:28 AM »
Need some help here please.
Have got a F2 engine that seems to be in good order. Camchain and tensioner OK, the guides have been replaced. Like to determine if the primary chains are in good order. Removed the oilpan, chains look OK, tensioner also. Is there a measurement, from let's say the casing to the tensioner, so one could see if the chains need replacing??
Thanks in advance,
Rob
Offline CB750F2
  • Pat's first Honda 750 F2
Re: Primary chains
« Reply #1 on: October 01, 2008, 04:58:35 AM »
Yes there is. It would make easy if you could get hold of a service manual. The service manual expalins it pretty clearly. There are manuals that can be downloaded from this site. Pat
Regards
Pat from Australia
Offline mystic_1
  • 1970 CB750K
Re: Primary chains
« Reply #2 on: October 01, 2008, 06:45:10 AM »
Look HERE for manuals.
mystic_1
- John Augustus Shedd
Offline voxonda
Re: Primary chains
« Reply #3 on: October 01, 2008, 07:17:32 AM »
Thanks!!!!!!! I found it. It is within limit's so I can put some extra miles on it.
« Last Edit: October 01, 2008, 08:07:41 AM by voxonda »
