Author Topic: carbs cleaned- metal question  (Read 757 times)
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
« on: October 01, 2008, 07:01:33 AM »
Thanks to the group for the advise on carb cleaning...  One quick question...the float bowl and carb top are a different metal... so they appear very different to the carb body.   After I cleaned my carbs up... they didn't appear like the photo from an article I found on line...
Are these replacement pieces? Or is this normal?
Thanks again to everyone for their help.
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: carbs cleaned- metal question
« Reply #1 on: October 01, 2008, 07:12:15 AM »
The Honda CB's had polished float bowls and carb tops, throughout the line. So, what you have is 100% stock.
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
« Reply #2 on: October 01, 2008, 07:24:35 AM »
Hey thanks...  removes that concern from my plate.
much appreciated.
