Poll
hi
hello
1 (33.3%)
2 (66.7%)
Total Members Voted: 3
Author Topic: need some help with 1976 honda cb 500t  (Read 2229 times)
spew74
« on: October 01, 2008, 08:30:11 PM »
I am new here and was wondering if anyone could point me in the right direction on the best place to find parts to cafe out my honda cb 500t. ie. seat. etc. also i want to put pods and run stright pipes. does anyone know what jets if any i will have to get for the carbs? thanks a lot.
Offline KB02
Re: need some help with 1976 honda cb 500t
« Reply #1 on: October 02, 2008, 04:36:30 AM »
Check out the Honda twins site: www.hondatwins.com
It's a smaller, newer site, but just for the twins.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #2 on: October 02, 2008, 04:54:36 AM »
        Since the 500T is basically a 450, you could also check out this one too. ;) It's been around for awhile and has a pretty good amount of info and photos of member's bikes, to give some ideas.
               http://groups.msn.com/hondacb450dohc
Member # 1969
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #3 on: October 03, 2008, 07:54:34 AM »
This site helped me a lot when I did my 75 500t restoration.
Fonda Honda
Offline tbpmusic
« Reply #4 on: October 03, 2008, 08:59:44 AM »
I know something of 450's, essentially the same machine.
450's are amazingly tolerant of changes to filters, exhaust, and altitude, due to the principles of the vacuum carbs.
While the 500T's carbs are slightly different (they have slide springs and a jive accelerator pump-thingy), they're still basically the same carb.
As an example, back in The Day, I fitted a pair of 450's with Filtron filters (the precursors to Uni foam) and Hooker exhausts. Neither bike required any changes to the jets at all, and both had considerably improved performance.
Later, I moved with both bikes from Denver (over 5,000 feet altitude) to Indiana (about 600 feet), and again didn't have to touch anything.
So I would at least try it as-is for a little while and get a good plug reading first.
Also, FYI, while jets are changeable on those carbs, the needles are not adjustable.
bill2
Bill Lane
