Author Topic: Still not starting - but what is this all about?  (Read 2155 times)
Offline JerryRice
« on: October 02, 2008, 12:48:24 PM »
I am still having a problem staring my 1974 CB350F.
I tool the advice of a member and sprayed carb cleaner
in the air filers. The bike started for a short time
and stalled.
I noticed that only the left two exhaust pies were hot-
the other two cold.
Seems gas is flowin to the carbs. Also, There is
spark on all four plugs.
This is crazy. The bike used to start no problem.
What is going on?
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline Johnny5
    • CB350F build thread
Re: Still not starting - but what is this all about?
« Reply #1 on: October 02, 2008, 12:56:43 PM »
Something clogging the fuel system? Sounds like it's starving for fuel on the side that's staying cold.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline JP74
  • "i'll be at the garage"
  • always more work do...
« Reply #2 on: October 02, 2008, 01:16:32 PM »
how long has the bike been sitting?
how have you confirmed that fuel is getting to the carbs?
76-cb750k, 75-cb360T, 71-cb750k,
73-cb750 AMEN hardtail,
78-750k roller..cl350..cl450. kz400,gs750.  maybe more
Offline JerryRice
« Reply #3 on: October 02, 2008, 01:22:23 PM »
Bike was sitting for 2 weeks.
I confirm the fuel is getting to the carbs by pulling th
fuel line off the carbs.. yup its wet.
Also I removed the carbs and cleaned them out.
Re-conected the tank and turned the petcock on.
I have a clear fuel filter. The gas wqas pouring
through for a long time..confirming that the float
bowls were filling up.
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline JP74
« Reply #4 on: October 02, 2008, 01:32:12 PM »
have you tried pulling the float bowls off and measuring the amount of fuel?
float height set to specs?
you are getting strong spark on all four plugs?
Offline WFO
  • Will work for powerbands
« Reply #5 on: October 02, 2008, 01:33:50 PM »
Well this doesn't mean the float bowls were filling up on the two cold cylinders there is a drain screw on the bottom of the carb bowls loosen that and confirm the bowls do have gas in them also try to start and pull the plugs and see if they are wet confirming gas is getting into the cylinders (then go from there) check for spark on those two cylinders
82 cb650 sc nighthawk - 78 kz 650 b
Offline JerryRice
« Reply #6 on: October 02, 2008, 01:51:09 PM »
The spark is not that strong across the board. However I am not sure what the normal output should look like.
I will check the float boals by unscrewing tonight - will report back
tomorrow thanks!
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #7 on: October 02, 2008, 02:03:21 PM »
Should have a bright blue spark.
Still sounds like a carb issue.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline JP74
« Reply #8 on: October 02, 2008, 02:13:49 PM »
def sounds like a carb issue.    how in depth did you clean the carbs?
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #9 on: October 02, 2008, 02:20:29 PM »
I suggest that if your float levels are ok and your plugs appear dry then check your low speed jets for clogging. Pat
Regards
Pat from Australia
Offline WFO
« Reply #10 on: October 02, 2008, 02:27:41 PM »
tomorrow thanks!
I had a spark plug showing spark on a ATV it wouldn't start it ended up being a bad spark plug try switching plugs from a firing cylinder.
Offline Hush
« Reply #11 on: October 02, 2008, 02:31:31 PM »
+1 on the swapping the good plugs across to the cylinders not firing, also just a thing I do: drop a wee bit of gas into the cylinders that don't appear to be firing before you put plugs back in, if it fires with this form of backwoods fuel injection then yes you have proved its a carb problem. ;D
Offline JerryRice
« Reply #12 on: October 05, 2008, 12:00:23 PM »
Ok People. Thanks so much for backing me up with support trouble shooting this issue.
It seems to have been a loose kill switch connection. So far it starts. I may just
bypass the switch totally.
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline Johnny5
« Reply #13 on: October 05, 2008, 05:58:31 PM »
Be careful riding around without the killswitch.
Keep us updated on how the bike is doing.
1971 CB350
1973 CB350F
Offline JerryRice
« Reply #14 on: October 06, 2008, 06:54:19 AM »
Yeah, maybe I will just put on an aftermarket switch.
The Real JERRY RICE
My Dream Bike
www.CB350F.com
