Author Topic: Smoothing out the tank  (Read 1318 times)
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« on: October 02, 2008, 06:44:43 PM »
I'm going to  be repainting the tank on my 550 and am going to replace the honda name emblem with the wing decals. What  should I do about the tabs that  the emblems attach to? If I  bondo, the tabs look like they'll stick out a bit.
Angle grinder?
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
Re: Smoothing out the tank
« Reply #1 on: October 02, 2008, 06:57:09 PM »
On my '77 550 the tabs actually kept eating the bondo... They were recessed more than they look. Worst thing that will happen is you'll have to add some more material, slightly change the shape of the tank, but in the end you'll still have a smoothed out tank right?
« Last Edit: October 02, 2008, 07:01:39 PM by Sporkfly »
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: October 02, 2008, 09:18:43 PM »
You'll need to build up a bit anyway in order to follow the curves of the tank, so height of the mounting bars isn't a problem.  You don't have pins broken off and still in the holes, do you?  If so, yank them out with pliers.  I started with a chopped-fiberglass filler (Tiger Hair) and finished with bondo.  Worked well.
mystic_1
- John Augustus Shedd
Offline jason teamshralp
« Reply #3 on: October 02, 2008, 11:45:46 PM »
you can cut the little squares out of the valley they sit in. Then add metal, or just bondo. I left mine in place and pressed bondo into the mounting holes, i fiqured that would give it something to hold onto. I did have to do like three different layers of bondo because I kept sanding down to the bracket. But I got it nice and smooth, like they were never there.
Offline DavePhipps
« Reply #4 on: October 03, 2008, 08:25:36 AM »
Thanks guys. The info was much appreciated
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline crazypj
  • I'm brill, me
« Reply #5 on: October 03, 2008, 09:46:34 AM »
I bash the tabs in flat onto tank first. leave them in place so Bondo has something to hold onto.
PJ
Offline KB02
« Reply #6 on: October 03, 2008, 09:59:29 AM »
PJ
On my '76 750F tank, I cut the tabs off with a cutting bit on my dremel tool. When I get ready to apint the tank for my current project, I'll probably do what PJ suggested.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
