The SOHC/4 World Tour is in under way.
Nevermind. I just found the piece you were talking about. There should be no issue in removing that piece and therefore the tab, correct?
Quote from: bunghole on October 04, 2008, 06:43:25 pmNevermind. I just found the piece you were talking about. There should be no issue in removing that piece and therefore the tab, correct?if you leave enough tabs to some what hang the engine in and at least one point to bolt a wheel too and maybe a tank,you can grind away as much as you want...
