Author Topic: Front fork axle holder stud question - 1981 cb650  (Read 1937 times)
Ostiosis
« on: October 06, 2008, 08:37:20 AM »
I recently changes the fork seals on my 1981 cb650 (which was way easier than I thought it would be  :) ), but when I was looking in my Haynes manual I thought it said to torque the axle holder nuts to 40 - 47 ft lbs.  I look online and find out that is supposed to be 13 - 18 ft lbs.  Luckily, it striped out on the nut and the lower part of the stud, and the slider appears to be fine.
I have the new studs on order (I hate waiting) and was just wondering if any of you had tips for torquing the studs into the slider?  I guess I should add that I don't know if you use a standard torque wrench with a strap socket or something?
« Last Edit: October 06, 2008, 09:01:35 AM by Ostiosis »
Re: Front fork axle holder stud question - 1981 cb650
« Reply #1 on: October 06, 2008, 09:29:26 AM »
Just wind em in tight its near on impossible to torque a stud
Offline crazypj
  • I'm brill, me
« Reply #2 on: October 06, 2008, 11:02:21 AM »
You can get hold of a Snap-On CG500 stud installer but I doubt if there is a fitting torque for the studs into fork lower.
 Just double nut them and use loctite if your worried. ( personally I wouldn't bother)
I would probably just grip old studs in soft jaws in bench vice and turn them out with adjustable wrench on the flat part
PJ
Ostiosis
« Reply #3 on: October 06, 2008, 11:02:40 AM »
Does anyone think it would be stupid to use an 8.8 grade bolt and grind off the head?  I am trying to get in some riding before winter comes to Vermont  :)
The dimensions on the bolt are 8x1.25x55 and I believe the studs are 8x1.25x49.  This would just be while I am waiting on Motogrid to deliver my parts.
By the way thank you guys very much for your help.
« Last Edit: October 06, 2008, 11:27:11 AM by Ostiosis »
Offline dusterdude
« Reply #4 on: October 06, 2008, 12:10:10 PM »
can i assume your local hardware/bolt supplier doesnt have 8mm studs?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Ostiosis
« Reply #5 on: October 06, 2008, 12:19:13 PM »
10mm are the closest I have found.  I haven't checked Home Depot yet though.
Edit: Home Depot doesn't have them either :(
« Last Edit: October 06, 2008, 12:34:20 PM by Ostiosis »
Ostiosis
« Reply #6 on: October 06, 2008, 03:39:50 PM »
I am going to assume that this is ok, wish me luck :)
martino1972
« Reply #7 on: October 06, 2008, 06:30:25 PM »
whatever you end up doing is up to you,but be carefull,it IS holding your front wheel in place..!!!!
Ostiosis
« Reply #8 on: October 06, 2008, 09:21:04 PM »
I ended up leaving the head on a 8x1.25x60 bolt, which left enough room to have a nut, the washer and the spacer on it.  Then I threaded it into the lower sliders.  I tightened the bolt down first (being careful not to overdo it), and then tightened the nut into place.
I will take it on a short test drive before I go all out, but I think it will work as a temporary fix.  I will ask someone at the motorcycle place tomorrow if they think it will be OK.
BTW your cb650 bobber is a huge inspiration for me, I hope I can make mine as cool as that  :)
