Author Topic: 74 550-Ninja Hybreed-Coming Out Pics  (Read 46930 times)
Offline Soos
Re: 74 550-Ninja Hybreed
« Reply #100 on: April 12, 2009, 02:33:07 AM »
Life is a necesarry evil huh?
paying bills n such.
Good luck on the small business!
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline moham
  • .fnord.
« Reply #101 on: April 29, 2009, 10:14:19 AM »
Well, I'm goin' in...gonna get this shyte done, like now.
Oh wait, I'm still sittin here on my ass, aren't I??
To the motor!
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline moham
  • .fnord.
« Reply #102 on: April 29, 2009, 11:32:52 AM »
btw, anybody use Pro Circuit PC-03 as an assembly lube? Guys at the Honda shop said that's what they use instead of redline or others...
78 750K-The Ocho
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #103 on: April 29, 2009, 02:23:31 PM »
I've used it before.
Good stuff.
Cannot really tell the difference from the others though. Maybe because I don't tear it apart right away and look for wear?
Well either way it's good.  ;D
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #104 on: April 29, 2009, 03:55:20 PM »
I re-read paulages hybrid thread last night (about 16 pgs anyway) and am wondering now if the 550 carbs are going to be sufficient. He used 750s but was at 718cc vs my 573cc. I think I'll start with the 550s and go from there.
i have a set of '79 cb650 slide carbs i'd let go for cheap if you'd like to try those over the 550 carbs. they have accelerator pumps, but adjustments aren't quite as easy as with the older carbs. it's the mains you'll have to #$%* with the most anyway, and those are readily available.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline moham
  • .fnord.
« Reply #105 on: April 29, 2009, 04:07:52 PM »
What shape are the 650 carbies in? I've already re-built the 550s and I remember Soos saying that 650 carb re-builds get a little spendy...
If they are in decent shape and not requiring a lot of re-build time, I'll take you up on that offer.
78 750K-The Ocho
Offline Soos
« Reply #106 on: April 29, 2009, 07:18:18 PM »
Hey moham... pm sent.
-=≡ Soos ≡=-
Offline paulages
  • 1976 cb735
« Reply #107 on: April 30, 2009, 01:57:00 AM »
they're in good shape (the bike only has 3000 miles on it), but i'll be in europe until early june if that affects your decision. i have no use for them though, so just let me know. i could probably get someone to pack them up for me too if necessary.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline moham
  • .fnord.
« Reply #108 on: April 30, 2009, 08:42:55 PM »
Soooooo, began getting the lower cases together (it's going ok, thanks for asking) and was looking at the upper case and realized something was not looking quite right. (See attached foto below for visual aids).
Now, I'm pretty sure I know the answer to this question, but I want to hear from the audience: replace curvy stud or not replace curvy stud?
78 750K-The Ocho
Offline moham
  • .fnord.
« Reply #109 on: May 06, 2009, 08:54:42 PM »
OK lads, ready to "mate" the lower cases. Anything look weird, out of place or just dead wrong?? I've been working through the manual and all of the shots I took during de-construction and I'm pretty confident, but, never hurts to ask...Also, do I butter up the transmission good with lube?
78 750K-The Ocho
Offline paulages
  • 1976 cb735
« Reply #110 on: May 07, 2009, 04:29:44 AM »
i'd lube the trans gears a little (i use a little 50W/40) if they're new and sticky. you didn't really need to lube the cases where the big outer trans bearings go, as the don't move against the cases. as far as the gears in the trans go, i wouldn't worry about it. the little needle bearing that has a mini oil pump going to it (end of the countershaft) could use a squirt. just kick the oil through a little before starting. being a wet sump engine, the oil's right there anyway...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline moham
  • .fnord.
« Reply #111 on: May 12, 2009, 09:01:01 PM »
Well, I need to know if I'm missing an oil seal here (refer to pic below) just up and left of the left-hand bearing set-plate hex nut, my disassembly pics (of which this is one) show what looks like a seal. My cases were blasted and I'm not finding it in my parts bags, and, to boot, the parts fiche(s) is/are not turning up what I think I'm seeing. Is there supposed to be a seal there or am I hallucinating yet again??
78 750K-The Ocho
Offline moham
  • .fnord.
« Reply #112 on: May 12, 2009, 10:08:03 PM »
Now for the clutch issue...
Bought the Barnett kit awhile back and was surprised to see one thicker (3.4mm) friction disc out of the 7 total (other six are 2.7mm). Emailed Barnett at the time and they insisted this was correct and that the wider tabs in the thicker friction plate would put it as the last to go into the stack, since the basket slots are tapered. Only thing is, they are not tapered and the thick disc does NOT fit. Apparently they should all be 2.7mm...
78 750K-The Ocho
« Reply #113 on: May 13, 2009, 04:33:13 AM »
There is not supposed to be a seal there. That clutch disc you mention with the wider tangs is meant for the 77-78 model clutch basket I expect.
Offline moham
  • .fnord.
« Reply #114 on: May 13, 2009, 07:07:24 AM »
Thanks, after staring at the photos again for awhile  I decided there wasn't one, that the LSD was to blame, once again.
I didn't know the 77-78 clutch baskets were different. Only bummer is, now I have to wait for an extra disc....
78 750K-The Ocho
« Reply #115 on: May 13, 2009, 04:13:12 PM »
Have you got a set of Barnett springs? They are supposed to be the ticket if you making a little extra power. That or shim the stock springs.
LSD huh? I try not to think about those days long ago & far away.  :P
Offline moham
  • .fnord.
« Reply #116 on: May 13, 2009, 05:43:16 PM »
Got the springs to go with the plates. Also talked to Barnett and the guys that sold me the kit, Niche Cycle (selling on ebay, of course), and they're shipping the extra plate to me. Barnett didn't seem too interested when I emailed yesterday with this issue.
You know, about the acid, it turns out that all those parents/teachers/etc telling you it would fry your brain, yeah, apparently they were right. I've tried to forget it, but IT won't let me...
Damn you, Timothy Leary...
78 750K-The Ocho
Offline CBJoe
« Reply #117 on: May 13, 2009, 06:21:57 PM »
And I kept wondering why your avatar moved back and forth from Burroughs to Thompson  ;D
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline martino1972
  • and still a expert welder,period...
« Reply #118 on: May 13, 2009, 07:11:44 PM »
putting up a reply so it shows up in my visited posts........following this build.. it's interesting....
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
Offline moham
  • .fnord.
« Reply #119 on: May 13, 2009, 10:20:27 PM »
I've gotten most of the way on reassembling lower half. Just waiting on a couple parts to finish. Next comes the interesting part, mating the cylinders and mounting the ninja pistons. (Did I just say "mating" and "mounting" in the SAME sentence?! God I'm good...) Don't know if I'll be able to start on that tomorrow, still have too many projects rolling at the mismo tiempo. Gears all shift through so that's a good sign.
I'll be f-ing amazed if this thing actually works when I'm done.
78 750K-The Ocho
Offline moham
  • .fnord.
« Reply #120 on: May 15, 2009, 05:53:50 AM »
Some progress shots...Started ringing the pistons yesterday and pulling together the rest of the stuff to cylinders/head. Part of my re-build time has been spent looking for the boxes of new parts that have been sitting around gathering dust for the last couple of months.
We're gettin it, tho...
78 750K-The Ocho
Offline Soos
« Reply #121 on: May 15, 2009, 06:42:32 AM »
Looking good so far Moham.
Are you able to take video once you get that thing running?
l8r
-=≡ Soos ≡=-
Offline moham
  • .fnord.
« Reply #122 on: May 15, 2009, 07:46:23 AM »
Fo Sho...
78 750K-The Ocho
Offline moham
  • .fnord.
« Reply #123 on: May 15, 2009, 12:37:31 PM »
So I've been looking at the exhaust side cylinder stud that has the tiniest tweak in it and have tried a couple things to get it loose like double-nuts and dual vise grips. Ample Kroil as well with some heat on the casing but it's not moving. I think I might try just sliding the block and head on to see if it's going to be an issue or not. Any thoughts on this strategy? I've got a replacement in hand but it won't do me any good if I can't remove the old one...
78 750K-The Ocho
Offline HavocTurbo
  • Can you tell?
« Reply #124 on: May 17, 2009, 10:41:00 PM »
May seem like over kill....
I usually cut them off as flush as possible. then drill with consecutively bigger drills until I can remove it with an easy out.
I also *soak* it in as much lubricant as possible and use heat when trying to remove.
09 XL883L - No Name
