Author Topic: Winker blinking speed  (Read 1788 times)
Offline Johnny5
    • CB350F build thread
« on: October 10, 2008, 04:50:01 AM »
I think Winker just sounds funny. First time I heard a blinker called that was from reading the Honda Shop Manuals. Anyway, my bike is still new to me and as I go through the little bugs I found that the blinker speed is normal with the engine revving, but like a turtle at idle. I checked my battery voltage and that checked out good. Does this sound like a faulty relay?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline mystic_1
  • 1970 CB750K
Re: Winker blinking speed
« Reply #1 on: October 10, 2008, 05:34:27 AM »
Need more data.  Testing the battery voltage is a start (I'm assuming you did it with the bike off) , but what's the voltage reading at idle and when revving?
That said, replacing the winker relay is cheap, go with an electronic winker, they always blink at the same rate regardless of load.
mystic_1
- John Augustus Shedd
Offline Johnny5
« Reply #2 on: October 10, 2008, 05:54:53 AM »
Yeah, I checked with the bike not running. It was too late at night to check while revving.
1971 CB350
1973 CB350F
Offline Alan F.
« Reply #3 on: October 10, 2008, 05:55:39 AM »
Nah, it's the nature of the beast.  These bikes don't charge until you get the revs up, so the blink/winkers will flash slowly, your horn will sound weak or won't work at all, and your headlight may be a little dim (turn it off if you can to save your battery for starting, or use low-beam at least) .....at idle, but go to full strength when you get the revs up past......what's the magic number for a 750?  is it like 1300 rpm or more like 3000?  I know that while riding around town you should try to keep the revs up a little high/stay in too low of a gear, to keep things charging and not running solely off the battery.
Look at it this way, after cranking my 92 'cb750' ::)  to life last sunday morning at about 42 degrees out, the horn wouldn't beep until the revs went up. (I bumped it by accident going for the choke)
Offline Johnny5
« Reply #4 on: October 10, 2008, 06:15:12 AM »
So what you're saying is that if my charging system is fine, a new flasher relay wont change anything?
1971 CB350
1973 CB350F
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #5 on: October 10, 2008, 06:19:11 AM »
Mine do the same thing only they're 'normal' at idle and race to the point of that buzzer sounding like a freaking siren with the revs up!
Yep, I'll be watching this one a little bit.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline Steve F
« Reply #6 on: October 10, 2008, 06:32:56 AM »
Get yourself an electronic flasher relay from the local auto parts store.  They (as in most of them) don't care what the voltage is, within reason, of course.  They usually require three connections, (+), (ground), and load.  Pay close attention to which wire is which so you don't fry the thing.
Mine works flawlessly, regardless of the rpm's.
Offline Alan F.
« Reply #7 on: October 10, 2008, 06:38:00 AM »
Sporkfly, you may need to check the voltage your system is running at (with the engine running, and the revs up a bit) if your voltage regulator is misadjusted you could potentially be running a bit high.... Expert opinions please...??
Offline Accolay
« Reply #8 on: October 10, 2008, 05:02:45 PM »
If you need a new relay, I recommend Z1 Enterprises. My bike had a relay in there that made the interval between flashing really long. AND this one comes with the correct rubber holder that my bike was missing.
http://www.z1enterprises.com/detail.aspx?ID=1967
1977 CB550F
Offline kghost
« Reply #9 on: October 10, 2008, 05:07:58 PM »
The old relays/wiring/sockets build up resistance then flash is  slow or not at all.
They then tend to flash when the voltage builds with Rev's.
You could put a new battery in the bike and it would still do it.
Stranger in a strange land
