Author Topic: How are you guys changing your own tires without chewing up your rims?  (Read 6446 times)
Heironymous Josh
Re: How are you guys changing your own tires without chewing up your rims?
« Reply #25 on: October 12, 2008, 10:44:33 AM »
Motorcycle wheel attachment
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #26 on: October 12, 2008, 03:02:04 PM »
(here is an (modified) older post of mine regarding tire changing from this thread: http://forums.sohc4.net/index.php?topic=36069.msg372096#msg372096 )
I found that the right tire tools were everything. I would NEVER even THINK about using a screwdriver, however, as I tried that (before I got a tool set) and promptly put a hole in the tube, despite being beyond careful.
I used this set of tools that can be gotten off of feeBay for like $30. The spoons are flat and really broad (unlike a screwdriver) and though I slacked and didn't put duct tape on the rim or anything (like a lot of peeps recommend to protect it) the chrome was fine.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&item=330243126521
It was the bottom tool that was the best - I ended up buying another one of those, actually, as you can really get a lot of leverage with it. The middle tool is nice for moving the bead over the rim.
Also, some form of lubricant on the rim and tire REALLY helps immeasurably. I just used a bit of Simple Green in a spray bottle - worked great but I have heard others using silicone, grease, etc. (I was worried that the latter would be too persistent and maybe the tire would slip on the rim - possibly shearing the stem?) I checked said rim/tire over a year later and there wasn't any residual water inside or rust from the spraying, either.
I also found a rubber mallet is perfect for getting that last 6" or so over the bead (THE hardest part of all of this, to do - see next post (what jogged my memory)). I got one at Wal-mart for like $1.99. While trying to lever that last bit over, a few whacks with the mallet kinda sideways on the bead made it WAY easier!!!
« Last Edit: October 12, 2008, 03:05:14 PM by MoTo-BunnY »
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
