Author Topic: I think I need more links in my chain  (Read 1665 times)
Offline Really?
« on: October 11, 2008, 01:25:25 PM »
See the indicator line, it looks a bit far up.  Currently, it is a 120/90-18 and am going to a 130/90-16.  There is very little space between the tire and the bar that holds the brake hub.
What amount of links in a chain will I need to accomplish this?  The rear sprocket is a 48 tooth (I tried counting, lol), I guess normal up front.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline WFO
  • Will work for powerbands
Re: I think I need more links in my chain
« Reply #1 on: October 11, 2008, 01:36:33 PM »
Hows the tension?
82 cb650 sc nighthawk - 78 kz 650 b
Offline Really?
« Reply #2 on: October 11, 2008, 01:58:15 PM »
In my opinion, tight.  It sounds like it creeks when the wheel is turned.
Offline WFO
« Reply #3 on: October 11, 2008, 02:14:34 PM »
Well it looks like your on the scale you could add one more link so it's not so tight.
KingCustomCycles.com
« Reply #4 on: October 11, 2008, 02:34:04 PM »
It is OK. If it is a new chain, you will get a fair amount of slack the first time you ride it.  I have had to make my own brake stay bars because of the 4 inch stretch and wide tires on my bobbers.  I use 1/2" OD steel tubing and weld tabs into notches cut in each end.  drill and spritz with krylon satin black and off I go.
Offline Really?
« Reply #5 on: October 11, 2008, 02:36:31 PM »
I was figuring it should be a little further back as it is but I was also thinking that it should go back a bit further to give a tad more room to fit the 130 in there and miss the brake hub bar.
So you figure a few more links should do it?  Where can I get these?  You new this question was coming, lol.
Offline Really?
« Reply #6 on: October 11, 2008, 02:38:30 PM »
I doubt this is a new chain, it looks like it has been there a while and was there when I got the bike a month ago.
Offline WFO
« Reply #7 on: October 11, 2008, 02:47:31 PM »
Well if your goal is to make the other tire fit ( that's your call ) i don't think anybody here can give you and exact number of links to add to acheive this but you also say you don't know how old the chain is but what you can do it take it off and lay it flat on the ground and pull on each end to see how much of an arch it makes. A new chain has very little arch and a used chain well you get the idea but i would determione is that chain you have is worth keeping first for the sake of safety.
Offline heffay
« Reply #8 on: October 11, 2008, 02:53:06 PM »
and most likely due to being old... get yourself a new chain w/ 4 or 5 more links.  usually less than a hundred dollars well spent.
Offline Really?
« Reply #9 on: October 11, 2008, 02:56:10 PM »
I have seen 90 and 100 link chains.  What is a good start?
Offline heffay
« Reply #10 on: October 11, 2008, 03:00:42 PM »
count the links in your old one  ;)
Offline Really?
« Reply #11 on: October 11, 2008, 03:10:08 PM »
I will do that.  I was thinking about doing that too but yanno, I was being lazy, lol.
Offline kghost
« Reply #12 on: October 11, 2008, 03:18:07 PM »
Most new Heavy duty Chains come with about 110 links....More than long enough for a 750.
Stranger in a strange land
« Reply #13 on: October 11, 2008, 05:47:07 PM »
126 link 530 HD chains are less than $30.00 from JC Whitney online.  I have used 10 or so of them.
Offline 333
  • Time for change
« Reply #14 on: October 11, 2008, 09:42:06 PM »
Tire size shouldn't be an issue unless there is a typo in your initial post.  You said you were going from a 120/90/18 to a 130/90/16.  Then as discussed in probably many chain posts, don't put a new chain on old sprockets, or vice versa.  These two items wear at the same rate and replacing one without the other will cause premature wear in a fraction of the normal wear time.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline oldbiker
  • I HATE RAIN
« Reply #15 on: October 12, 2008, 12:19:06 AM »
With a 530 chain, 2 extra links will move the wheel back 5/8"
« Reply #16 on: October 12, 2008, 05:37:12 AM »
The more links in your chain, the more likely someone will pull it..... ;D Good morning Gigawhiskey!
