Author Topic: What is the weight of CB750 Carrillo H beams?  (Read 1290 times)
« on: October 11, 2008, 10:49:26 PM »
 Gordon.....I know you measured them and the search got me nowhere.
Re: What is the weight of CB750 Carrillo H beams?
« Reply #1 on: October 12, 2008, 03:34:02 AM »
Re: Weights Of Internal Components Documented - Finally CB750 K4  page 2 (includes the shells though)
http://forums.sohc4.net/index.php?topic=19219.15
« Last Edit: October 12, 2008, 03:49:42 AM by bwaller »
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #2 on: October 12, 2008, 05:04:37 AM »
Mike, my set of 4 came in a carton of 4 inner packs - they had "317" stamped on each box and a sheet included that stated these were a matched set of rods precision machined to 317 grams each. Actual measurements with this jewelry scale showed only .3 gram difference between all 4.
Here is a visual record of that measurement. Jerry had started a database of rod weights, but I don't know where we left it -
Regards, Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
« Reply #3 on: October 12, 2008, 06:36:01 AM »
 Thanks guys. I want to have a record of all the CB rods I've seen. I'll be weighing a JET Ti rod and a friend of mine has some Golden Rods. I had weighed the Falicon's from Art's bike but I can't find the info. Falicon doesn't supply much in the way of diameters or weights with their pieces.
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #4 on: October 12, 2008, 06:38:08 PM »
Mike,
I'll look through my build packet and see if the numbers are in there.
Art
1972 CB750 K2 Cafe' Style
« Reply #5 on: October 12, 2008, 07:40:28 PM »
Mike,
Art
Thanks Art. Those stickers are in the mail.......finally. ::)
« Reply #6 on: October 12, 2008, 10:38:03 PM »
And if I know Mike, he doesn't give a s^&t about the varying weights of the rods labeled CR750  ;D
