Author Topic: my electrical problem  (Read 1400 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« on: October 12, 2008, 09:08:43 PM »
Here is what the CB750 is doing.
I can't get juice to the electric starter button unless I am hooked up to my van via jumper cables. And then, only occasionally.
In the morning I don't even have enough juice to kick the bike over, so that's when I get the cables out. After I ride somewhere, I can kick the bike over no problem.
I had a buddy check the system with the meter, and it read 13.5 volts the other day.
any ideas?
1978 CB750K8; 1970 CB450
Re: my electrical problem
« Reply #1 on: October 12, 2008, 10:17:36 PM »
Didn't you already say in another thread that you let the battery get low on fluid?
Did you have the battery load tested?  Or, try a different known good battery in the bike?
Offline gregwaits
    • waits music
« Reply #2 on: October 12, 2008, 10:33:30 PM »
I did say that. I guess even though the trickle charger shows I have good volts, I didn't load test it.
Maybe the battery is just shot.
Offline speedy gonzalais
« Reply #3 on: October 13, 2008, 03:23:13 AM »
Its not the volts but the amps you should look at, a battery will hold 12v untill its almost dead but wont hold the amperage needed to crank the engine, King is right the batt is most likley f***ed and its prob time to buy a new one.
82' C90
87' yamaha T80
79' CB125T/CD200 project
82' CB650z
80s kawasaki ae50/150cc project
92' Suzuki GSXR600
80' CB250N
« Reply #4 on: October 13, 2008, 08:18:11 AM »
Well, it's your choice.
You can overhaul the starter
Overhaul the starter solenoid.
Or, overhaul the starter control wiring/switches.
Or, have the battery load tested before doing those things.
What do you think is the best approach?
