Author Topic: Initial jetting recoommendations for '78 750 with MAC and Pods  (Read 1699 times)
Kamerer
« on: September 19, 2005, 08:33:07 PM »
I've come to Chicago to pick up a bike and ride home to Seattle. All is well and tuned, but I find the PO did not re-jet to accomodate the K&N pods and MAC 4-1.  All other basic specs on the bike are set, and I want to drill the jets out to make the long ride home smoother.  Does anyone have a quick recommendation about sizes to drill the slow/main jet and where to set the air screw.  Again, a 1978 750K model. Thanks,
Bryan
Seattle (Chicago at the moment!)
Hondalubr
Re: Initial jetting recoommendations for '78 750 with MAC and Pods
« Reply #1 on: September 19, 2005, 09:19:50 PM »
Is that an F or K model??? If it is an F you don't have to drill the slows out. You just have to twist and pull. DO NOT ROCK THEM side to side. They will come right out with finesse. If it is a F model the slows are 35s stock and the mains are 105s. You will need to go larger to compensate for the excess air. You may have to try an assortment and see what works best. The new slows just push right in, they do not screw in. I would search "Slow Jets" and read some of Buffo's post on this subject. I think he has a K8, I have an F3 so one of our posts would be good to read. The guys replied to mine and I was able to get mine done without a hitch. So good luck and have a safe trip.
Mike
Offline mikeb4
  • Building and riding and building ....
    • Mikeb4's website
« Reply #2 on: September 20, 2005, 08:05:11 AM »
On my 1977 750F model in Michigan I was able to get it running perfectly with 120 mains, I left the pilots alone (cleaned them out really well) and went to 4 turns out on the mixture screws.  I am running screened velocity stacks and a MAC 4 into 1 with the baffle gutted out but the endcap intact.  Hope this helps! ;D
Mike
1978 CB750K CR750 Replica
1995 CB1000F
1994 Sportster Bobber
1977 CB750SS Cafe'
1999 ZRX
Offline KB02
« Reply #3 on: September 20, 2005, 08:50:23 AM »
Mike
If it's the bike that's in his Avatar, It's the K model (and a nice lookin' bike, too!)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Kamerer
« Reply #4 on: September 20, 2005, 01:27:53 PM »
Thanks for the input.  I have 110 mains and the 35 slows.  I will work on the mixture screw, then - taking it way out to help the low end problem before I drill the slows.
Bryan
eldar
« Reply #5 on: September 21, 2005, 05:08:09 PM »
I would say to go back to the airbox since there have been problems with the pods that more and more people seem to report. You should not have to change anything other than to richen your low speed mix. Mains can be swapped like any other jets. But doing that means a sync otherwise you will still have a rough ride.
