Author Topic: Az to: Mount Rushmore, Sturgis, New Mexico, East Coast, NYC, back to Az.  (Read 67496 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
Re: Az to: Mount Rushmore, Sturgis, New Mexico, East Coast, NYC, back to Az.
« Reply #150 on: August 16, 2009, 05:02:00 PM »
Whats on your list of bring-alongs?
I have already:
Front/Rear tube
mini bicycle pump
Every tool I use on a semi regular basis
Extra chain
Fuel line/filters
Extra regulator/rectifier/coils + fuses
Also, did you run D7EA's or D8's?
1974 CB550
Forever West
Offline kpier883
  • is quite the
« Reply #151 on: August 16, 2009, 07:39:53 PM »
Those pistons look like someone put Comet in your oil :D
The only motors that I have seen that failed from a lean mixture are dirt track or other race car engines.  I just haven't had a lot of experience with street motors failing.
Usually, what happens with race engines is they hole a piston, or the center of the piston "sinks"  This is usually from very high compression, heat, and a lean condition.  Detonation heats the piston and the material gets soft.  Then the pounding from more detonation pushes the piston top downwards.  In most cases, the engine holes the piston before the problem is noticed, but in a few cases, the sunken piston will be caught before total failure.
What you have there is interesting and I hope some others chime in with their thoughts.
How lean were you running?  Did you see evidence in other areas, such as hard cranking when hot, or with excessive blueing of the header pipes?
I wonder if detonation led to ring failure which then scarred up the walls...?
Please share what you can because I do NOT want my pistons to wind up like that.  I am running pretty lean on my 750 right now.
If your bike was lean enough to do that, you should have been getting great gas mileage.  What kind of mpg were you recording?
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline Shenanigans
  • Right turn?
« Reply #152 on: August 17, 2009, 10:58:46 AM »
The D7s were a bit on the pale side, with a very light deposit. Not anywhere near being a nice tan color. The weird thing is that there was no blueing of the headers, it always cranked over fine hot or cold. The only evidence that it was running lean was that it ran out of go with some throttle left at 95 mph+ and that it would occasionally get really hot. IE every part of the motor would boil off water, even the back of the transmission. Dont know the exact mileage but it was pretty good.
A few pages back there was a list of all the tools I took.
Con Seann3ry
« Reply #153 on: August 29, 2009, 04:31:20 PM »
Just burned a Saturday afternoon reading your tales.  They're inspiring to say the least.  I've dreamed of doing some long distance traveling but haven't found anyone that rides and would be able to.  Since you did part of your travels with a companion and most of them alone I was wondering what your thoughts were on traveling alone.  Was it no big deal or if you did it again would you make sure to have someone else with ya?  Anyways, once my bike is charging I'm going to take it down the west coast along the 101 and have been a little worried about the trip.  After reading your story, however, I feel like I can take on anything.
Offline Shenanigans
  • Right turn?
« Reply #154 on: September 01, 2009, 04:11:07 PM »
Its a lot safer with two people. Its a lot easier to find solutions to problems with two people, easier pulling your bike out of a ditch. A little bit safer when in a sketchy area. 4 eyes looking for the exit instead of 2. When a bike breaks down you can always run to the nearest town to get a part with the other bike or go get water and food. Or I suppose go get help in unfortunate circumstances... You can watch each others bikes to make sure nothing is about to fall off or slide into a wheel. Ever see a CB try to eat a sleeping bag? Its also nice to have someone else to talk about the events on the way or have a conversation when your waiting out any long hours. Logically its the more "correct" way to travel.
But there is just something about being alone, maybe it might not appeal to everyone but it does to me. I dont know exactly what it is either. Its a hard thing to try and say but it helps you view everything in a different way... I need a while to think on how to write it haha.
It sounds kinda stupid but seriously go for it, so what if your bike breaks down? You will make it home somehow, if not at least you will make it somewhere. I always hear people say as an excuse something along the lines of "What if I break down in the middle of nowhere in the middle of the night?" You dont stop existing if something goes wrong, there will always be an outcome. I dont think anything can really ever go "wrong" maybe just unplanned. You may have to sleep a night on the side of the road then push the bike for a while then hitch a ride somewhere then hike back but there will always be an outcome. Which I think is all that will matter in a year, or 5 years later. or 40. (not that I am going to make it to that age)
And sometimes when the #$%* hits the fan and everything is lousy, it can often be much more enjoyable to remember and look back on something then it was when you were actually doing it...  ;D
« Last Edit: September 01, 2009, 04:29:56 PM by Shenanigans »
Offline IAmCitizenMe
« Reply #155 on: September 01, 2009, 04:47:37 PM »
As a journalist I can honestly say... What a quote!
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #156 on: September 01, 2009, 05:48:04 PM »
Riding alone means you don't have to stop for food, drink or a pee unless you say so!
It's the ability to be master of the day, go where you want at what ever speed, stop when ever you feel like it, for as long or short a time as you please.
See a cool bar, no conversation needed, want to go for a hike, do-it. Stop early cause your butt hurts, do-it ;D  Run at 100 mph for an hour do-it.
I loved the time I recently had on my bike alone ;)
I NEVER ever even thought about the "what ifs" .  Your on your own, put on your big girl panties and deal with it ;D ;D ;D ;D
« Reply #157 on: September 01, 2009, 05:54:54 PM »
Both you and Seaweb are my heroes.
Offline manjisann
« Reply #158 on: September 06, 2009, 10:11:18 AM »
This was great to read! I'd be happy to toss some money your way when you go on your next adventure! Think of it as an advance on writing a book, authors do it all the time. You have a great way with words, and made me laugh several times. If you are ever in SLC and Soos is too busy to help ya out, give me a shout, I'd love to help ya fix something or even just buy ya a burger.
Brandon
1980 CB650 Custom
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #159 on: October 28, 2009, 09:42:24 PM »
dont know why i didnt see this thread earlier, i just finished reading the entire tale of your trip and i'm impressed. i wish i'd done something like this when i was your age.
Mark Twain - Notebook, 1894
Offline Skonnie Boy
  • Cold cock
  • Life is not like a box of chocolates.
« Reply #160 on: October 28, 2009, 11:25:18 PM »
This thread inspired me to ride 2400 miles to (among other places) Lake Charles, LA., where I am pleasantly drunk and sitting in my underwear in a cheap hotel, ready to tackle New Orleans tomorrow.
You did freak me about running lean though.  Gotta check the plugs in the AM.
"Yeah, I'm hip about time. But I just gotta go."
  • The Stumped
« Reply #161 on: October 28, 2009, 11:32:31 PM »
Jeeeez, you should have said something before you left. I'm in Little Rock and going crazy adjusting to home life again. I would have rode with you in a heartbeat.
1974 CB550
Forever West
« Reply #162 on: October 28, 2009, 11:41:58 PM »
Your never too old Bucky, I'm doing the 4000 mile trip to Phillip island next year and then i want to visit some family in Western Australia next and thats about 10,000 miles.... ;)
Might have to lean on the Aussie forum members for a place to stay overnight on that one..
Offline Shenanigans
  • Right turn?
« Reply #163 on: October 28, 2009, 11:47:45 PM »
Epic multi-sohc4-member group trip? *cough cough  ;D
Just sayin'
Have fun for me in New Orleans, I never got a stop by there...
« Last Edit: October 29, 2009, 10:35:50 AM by Shenanigans »
« Reply #164 on: October 28, 2009, 11:51:05 PM »
Just sayin'
Wish i could ride on water, i would be in that in a heart beat.... ;D
« Reply #165 on: October 29, 2009, 07:55:29 AM »
Just sayin'
I that case you are talking Documentary. A group of people take 30-40 year old bikes on a long haul. Very compelling story.
Offline Skonnie Boy
  • Cold cock
« Reply #166 on: October 29, 2009, 08:13:45 AM »
Its not too late.  Feel like tackling Chicago in a week?  Yeah, neither do I.
Had I known, I would have taken a left around Muskogee, OK.  Dammit.
« Reply #167 on: October 29, 2009, 08:31:53 AM »
Bucky, just remember the $300  750 my buddy grabbed made the 2300 mile trip in a week with flying colors & wobbly wheel..
 The story I really liked was the 500 ride, think it was called.. They had to get a vintage bike for 500 or less, and ride from the central states to Portland, and most of them made it..
Offline Shenanigans
  • Right turn?
« Reply #168 on: October 29, 2009, 10:36:50 AM »
With the resources of even a couple of people, people they know, places to stay, it would be easy. Me thinks.
« Last Edit: October 29, 2009, 10:39:00 AM by Shenanigans »
  • The Stumped
« Reply #169 on: October 29, 2009, 02:12:21 PM »
Just sayin'
A small group of us serious guys should start planning. I'm already setting money aside and told my girlfriend to expect me to be gone twice as long this summer. I wasn't joking.
1974 CB550
Forever West
« Reply #170 on: October 29, 2009, 07:36:01 PM »
Think about this;
 Try to set up,
 An East Coast and West coast ride
 Plan a route to visit as many forum members as possible. They can help out with backyard camping, breakdown pickup, place to work on bikes, side trips to local attractions, etc
 Maybe pool a few parts in reserve, to ship out quick in case of serious problem..
 It would be great fun...
« Last Edit: October 29, 2009, 07:39:33 PM by 754 »
Offline bucky katt
    • facebook
« Reply #171 on: October 29, 2009, 08:53:18 PM »
Just sayin'
that WOULD be cool as hell wouldnt it? someone needs to contact the discovery channel. I'm in now that fuzzycycle lives again
Offline mrbreeze
  • Not your average
« Reply #172 on: October 29, 2009, 09:44:28 PM »
SO........whos'es gonna git this sucker stawted ???....The BIG run of 2010!!! 8)
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #173 on: October 29, 2009, 11:06:16 PM »
I stop for beer and photos to often for anyone to put up with me ;D
Offline Pinhead
  • 1979 CB652-ST
« Reply #174 on: October 29, 2009, 11:51:12 PM »
Yeah, a big SOHC4 run would be pretty kickass.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
