Author Topic: 750 lives again...  (Read 995 times)
ev0lution7
750 lives again...
« on: October 16, 2008, 04:33:13 PM »
I know i already had my bike runnig but many of you know that i took a spill a bit ago (about one month) and wipped out my stator cover and some other parts...
Well this morning i got it running while it was down i bought some 120 mains for it (its a CB750k 77') and reset the float heights somehow i missed that last time and they were all out of whack... i bought some oil seals and a new tach cable and replaced the tach seal and the shifter seal ... both were leaking and i pulled the pan and cleaned and painted the oil pan and cleaned and painted the oil filter and changed the oil and put 20-50 in there this time... it seems much happier now that it has good oil and i also cleaned the plugs and set everything up all i have to do is re align the front end and re tighten the front tripple tree and i should be back on the road minus a headlight and fender that should be here anyday now :)
anyway i will include tips and tricks on the stuff i did soo far i will just keep resurecting this thread as i have time to update!
Offline Johnny5
    • CB350F build thread
Re: 750 lives again...
« Reply #1 on: October 16, 2008, 06:37:54 PM »
Why did you buy bigger main jets? Did you change the air intake or something? Just curious.
Good job on getting it back on the road.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
ev0lution7
« Reply #2 on: October 17, 2008, 09:31:04 PM »
i had some flat spots when you hit the throttle @2k but once you got past that it was OK and also i was getting lean pop's at high loads like 100mph+ so i went to 120's and it has all but solved the problem i think i still need to goto 125's but i will see how it does on the road!
