Author Topic: CB 500 rectifier?  (Read 1788 times)
ROSKO
CB 500 rectifier?
« on: September 20, 2005, 10:36:42 AM »
Just wondering, is a CB 500 recdtifier the same as the ones used on the (350/450)twins?
« Last Edit: December 23, 2006, 08:17:59 PM by Glenn Stauffer »
Offline sidematic
Re: CB 500 rectifier?
« Reply #1 on: September 20, 2005, 11:31:15 AM »
contact oregonmotorcycleparts.com  He is very knowledgeable and will be able to provide with the part you need.
« Reply #2 on: September 20, 2005, 01:44:34 PM »
If you are trying to put the one in the picture on a CB500, then I'd say no.
You need a three phase rectifier.  Connector has six positions with one position unoccupied.  Three wires from the alternator and two to the bikes system; +12V, and 12v return.
Offline Paul
« Reply #3 on: September 20, 2005, 02:07:44 PM »
You don't say where you are from, but I had a bad rectifier on my 500 and I replaced it with with a new solid state one from
Farnell (www.farnellinone.....) or their other company in the US ..Newark. (The company ....not the place)
I got a new rectifier and heat sink for around $8.
Some say go with original but I recon if the new type were around when these bikes were being built they could have used these.
If you are stuck, let me know and I can get the part No's for you.
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
ROSKO
« Reply #4 on: September 20, 2005, 07:49:46 PM »
Thanks. I run oregon rectifiers on all my bikes, great stuff. I was asking because my buddy needed a new rectifier and I thought I'd pass an old one on for a temporary fix. It is 12/ 12 and six wire w/ one unoccupied... Just a thought.
« Reply #5 on: September 21, 2005, 12:18:12 AM »
It will probably work, then.  Just make sure the connector positions are correct.
« Reply #6 on: September 21, 2005, 01:09:13 AM »
NOPE a twin one will not work but any four one will including the dohc ones which have a built in electronic reg, you just need to know which wire goes where and somwhere i have a diagram
Offline oldbiker
  • I HATE RAIN
« Reply #7 on: September 21, 2005, 02:27:45 AM »
Rosko, the rectifier shown in your post is an old Selenium rectifier which is not very efficient. You must go for a modern Silicon rectifier. As other answers said, there are plenty of options open to you. Oregon is one that is highly recommended.
bike54
« Reply #8 on: September 21, 2005, 05:10:02 AM »
hi all
a little tip about old Selenium rectifiers easy to tell when they are faulty you dont even need a meter just smell it it will smell of rotten fish when faulty personaly when i come across them i automatically change them for a modern bridge rectifier (silicon)
mervĀ  :)
« Last Edit: September 21, 2005, 05:12:18 AM by bike54 »
