Author Topic: Can a 750F swinarm bolt be replaced by a .....  (Read 1343 times)
Offline Flying J
« on: October 18, 2008, 07:22:20 PM »
I want to put some rearsets on my 750f. i was thinking of just welding some brackets to mount a set from feebay and then eliminating the bulky aluminium pieces all together. So if i remove the current brackets the bolts for the swing arm (#1 in pics) will be to long as well as the other one, motor mount? (#2 in pics). My question is will bolts from a 750k fit this distance perfectly? Anybody know? or have done this.
these things are so Fugly.
fuzzybutt
Re: Can a 750F swinarm bolt be replaced by a .....
« Reply #1 on: October 18, 2008, 07:54:42 PM »
cut the bolt to length and re-thread it
Offline Flying J
« Reply #2 on: October 18, 2008, 07:59:28 PM »
I guess i could do that. I don't have a tap and die set but i will probably will end up needing one again. Thanks fuzzy for pointing out the obvious.
« Reply #3 on: October 18, 2008, 10:52:48 PM »
The K bolts off a 77/78 K should fit. If the frame is not wider on those years then all K bolts would fit.
I picked up some F parts, one of them fuglys is in good shape.. I will take a look to see if they maybe can be milled out to make them lighter & better looking.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #4 on: October 19, 2008, 06:17:36 AM »
I would imagine the swingarm bolt would work fine. The lower engine mounting bolt on the K model also holds the footpegs on and will probably need to be rethreaded or have a spacer added. It is probably shorter than the F model though.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline KB02
« Reply #5 on: October 19, 2008, 06:26:47 AM »
Okay - Not that I mean to hijack this thread here, but I'm actually going the other way with my rearset brackets. I have a K and want to use the Swingarm bolt to mount my rearset bracket with. I think we need to trade measurements (if not swing arm bolts  ;D ) to see if each other's idea are going to work.
1978 CB750K (rough measurements):
Swing Arm bolt: 12 7/16" (316mm)
Lower engine mount bolt: 13 11/16" (347mm)
What do you have?  ;)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Flying J
« Reply #6 on: October 19, 2008, 01:34:18 PM »
1978 CB750F (really rough measurements):
Swing Arm bolt: 14 3/4" )
Lower engine mount bolt: 17"
it was kinda hard to take these measurements with the parts on the bike but this gets you in the ballpark.
« Reply #7 on: October 19, 2008, 11:11:39 PM »
the fuglys can be made to look better!!
Look at the back of them, leave the thicker web portion, then remove the middle.. drill, hacksaw, & file.. or mill if you have one..
Offline KB02
« Reply #8 on: October 20, 2008, 04:52:08 AM »
Did you include the bolt head on your measurements? I did not for mine.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline Flying J
« Reply #9 on: October 20, 2008, 09:38:26 AM »
yeah i did :-X
Offline KB02
« Reply #10 on: October 20, 2008, 10:14:40 AM »
No biggie. The heads are probably the same size. I'll measure and post when I get home.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline KB02
« Reply #11 on: October 21, 2008, 07:18:33 AM »
Engine mount bolt and Swingarm bolt heads are 5/16" and 3/8", respectively.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
