Author Topic: Popping out of gear  (Read 2327 times)
Offline martini
Popping out of gear
« on: September 21, 2005, 07:08:44 AM »
My 750k0 has developed a nasty habit of slipping out of fourth into neutral. Thoughts?
With thanks!
Re: Popping out of gear
« Reply #1 on: September 21, 2005, 07:37:46 AM »
Worn dogs.
Offline Bodi
« Reply #2 on: September 21, 2005, 07:39:37 AM »
Worn shift drum and/or arms.
Worn gear dogs.
Weak shift drum detent spring.
Or a combination.
Offline martini
« Reply #3 on: September 21, 2005, 08:00:06 AM »
For the non-mechanic, such as myself, how big a job is it replacing the dogs?
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: September 21, 2005, 08:08:36 AM »
For any of the above it's an engine strip.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline martini
« Reply #5 on: September 21, 2005, 08:13:02 AM »
Yikes! Thats just what I did not want to hear.
    • TVAM
« Reply #6 on: September 21, 2005, 08:24:26 AM »
Look at it this way...
While you're in there, you can have a close look at everything else as well.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline dusterdude
« Reply #7 on: September 21, 2005, 08:36:23 AM »
yea build an 836 while you`re there.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
    • TVAM
« Reply #8 on: September 21, 2005, 08:37:26 AM »
Seems a bit extreme if all you've got is a few worn gearbox parts.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline dusterdude
« Reply #9 on: September 21, 2005, 10:04:53 AM »
now cmon steve,where`s your spirit of adventure and delving into the great unknown.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
    • TVAM
« Reply #10 on: September 21, 2005, 12:37:26 PM »
That's it Dusty.  The great unknown.
Why change a $200 engine strip into a $2000 big bore conversion?
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline dusterdude
« Reply #11 on: September 21, 2005, 12:46:08 PM »
awwww,im disappointed steve. :(
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
    • TVAM
« Reply #12 on: September 21, 2005, 12:48:11 PM »
My only experience with big bore kits was a 180cc CB125S I had in 1976. It was a moneypit.
SOHC4 Member #2393
2015 Tiger 800 XRT
« Reply #13 on: September 21, 2005, 02:11:40 PM »
It's a K0. It's 35 years old. If the transmission is acting up I'm sure the engine needs freshening up everywhere. The internal rubber parts are hard as a rock. The pistons probably have about .004 of piston to wall which means new pistons anyway which also mean cylinder boring. An 836 kit isn't unreasonable at all.
Offline Dennis
« Reply #14 on: September 21, 2005, 03:41:07 PM »
......... The pistons probably have about .004 of piston to wall which means new pistons anyway which also mean cylinder boring. An 836 kit isn't unreasonable at all.
So says the builder and Owner of the "Million Dollar CB"   ;D
Hop on a Honda
« Reply #15 on: September 21, 2005, 06:38:49 PM »
Couple of Questions.
How long has the CB been jumping from the gears and how many Milles has it done?.
I had a similar problem when I first had the bike of mine.
I changed the oil to pure mineral oil no more jumping out of gear and the clutch rattle stopped so did the slippage there too.
Dave Australia.
 ;D
Offline martini
« Reply #16 on: September 22, 2005, 07:21:18 AM »
Oh Happy Day!
Last night I pulled the cover of the shift mechanism and what did I find but one of the return springs had not been put in properly. Re-seated the spring - problem solved! No engine strip down required. Now if I could only get my carbs running properly.
Thanks for the replies.
Offline dusterdude
« Reply #17 on: September 22, 2005, 10:21:58 AM »
whoo hoo,way to go.now you wont have to bore steve with your 836 project. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
