Author Topic: Neutral switch?  (Read 1020 times)
Offline Johnny5
    • CB350F build thread
Neutral switch?
« on: October 24, 2008, 12:52:51 PM »
Is that the nuetral switch on the far right? The black circle with four holes in it? I need to check mine out. It's always lit, but a little brighter when actually in neutral.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
Re: Neutral switch?
« Reply #1 on: October 24, 2008, 01:31:24 PM »
You have correctly identified the neutral switch. Your problem sounds like a wire shorted to ground. If you remove the wire from the switch and the light stays on. then it is a short.
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
