Author Topic: 550 top end kit  (Read 1363 times)
Offline TE 450 Pilot
  • Just learning !
550 top end kit
« on: October 25, 2008, 04:27:24 PM »
Is there anyplace i can order all the parts to redo the top end of my 1976 550F ? Since i am going to have it apart i think i might just as well re-bore and drop in a 650 cam. Since this is my first project I'm not sure where or what i need to order.
Randy
Cambridge Ontario
1975 Honda 550F
1976 Honda 550F
2007 Husqvarna TE 450
2008 Husqvarna TE 250
Offline moham
  • .fnord.
Re: 550 top end kit
« Reply #1 on: October 25, 2008, 05:31:10 PM »
There are gasket sets available on ebay for more or less decent money. I guess there might be a dealer out there that still has oem sets. There are reviews (mostly not great) on this site of some aftermarket sets that are readily available for little dough.
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline OldSchool_IsCool
  • Really feeling like an
Re: 550 top end kit
« Reply #2 on: October 25, 2008, 08:07:35 PM »
I got a top end gasket set from http://www.westernhillshondayamaha.com/ a few years ago.  I haven't installed it yet, so I don't know what it's missing.  Oil gallery pucks maybe.
Sounds like you are looking for more then gaskets though, like pistons, rings, cam, valve seals...
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: 550 top end kit
« Reply #3 on: October 26, 2008, 02:21:17 AM »
I have a 555cc big bore piston & ring kit complete with head gasket available for $120.00 delivered.
These are quality Jananese parts.
FJ
  • Just learning !
Re: 550 top end kit
« Reply #4 on: October 27, 2008, 06:11:21 PM »
I have been reading FAQ's and doing searches for weeks on here. My wife already hates you guys  ;)
Any how, I just bought a 605 big bore kit for a CB500 of of eBay. I hope the post i read are correct that this kit will work on a 550. Do i need to use the sleeves or just bore the cylinders ? Will i need to change the cam or just do the port and polish thing when i go to the machine shop ?
Thanks for the help. This is going to be fun.
This kit is designed for the Honda CB500, CB 500, CB-500, CB500F, CB500-F, Four Cylinder Motorcycle, and will increase your engine size to 605cc.
It includes everything you see in the pictures:
KIT INCLUDES:
4- Hi Performance Pistons
4- Piston Pin with Clips
4- Piston Ring Set
4- Cylinder Sleeves
1 Hi Performance Head Gasket
SPECIFICATIONS:
Height of Piston:  44mm
Height from Top Ring to Top of Piston:  5mm
Outside Diameter of Piston:  60mm
Outside Diameter of Cylinder Sleeve at Top:  72mm
Inside Diameter of Cylinder Sleeve at Top:  60mm
Outside Diameter of Cylinder Sleeve at Bottom:  63mm
Inside Diameter of Cylinder Sleeve at Bottom:  60mm
Outside Diameter of Cylinder Sleeve at Center:  68mm
Manufactured by the SK / Sakura Kogyo Co, LTD from Japan. These kits were made back in the 70's.
« Last Edit: October 27, 2008, 06:13:04 PM by TE 450 Pilot »
Randy
Cambridge Ontario
1975 Honda 550F
1976 Honda 550F
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: 550 top end kit
« Reply #5 on: October 27, 2008, 08:28:54 PM »
Odd
605cc kits have 61mm pistons.
60mm pistons would yield a displacement of 572cc.
Formula = bore x bore x stroke x 0.0007854 = Cyl cc's
Example = 60mm x 60mm x 50.6mm x 0.0007854 = 143.068cc/ cylinder
143.068cc x 4 = 572.27cc
You might want to contact the seller for the reat of your displacement.
Offline moham
  • .fnord.
Re: 550 top end kit
« Reply #6 on: October 28, 2008, 11:04:03 AM »
Odd
Is there a difference of stroke 500 v. 550? I keep getting 592 when I do the math for a 61mm bore on a 550.
78 750K-The Ocho
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: 550 top end kit
« Reply #7 on: October 28, 2008, 01:07:36 PM »
No there is no difference in stroke between the 500 & 550. Only the bore changed from 56mm to 58.5mm.
You're correct, the 605cc kit is actually a 592cc displacement kit. I don't know why it is sold as a 605cc kit.
Somebody here could probably comment on that.
FJ
