Author Topic: can i still find an OEM in-tank filter for a 78 750F  (Read 1126 times)
Offline timdhawk
  • 1978 CB750K
« on: October 26, 2008, 09:25:01 AM »
mine is poo-poo.
would other years of similar design work. like from an 81 750F... ??
or should i just run an in-line and no in-tank?
thanks
« Last Edit: October 26, 2008, 09:28:05 AM by timdhawk »
In deeper than I should be...
Re: can i still find an OEM in-tank filter for a 78 750F
« Reply #1 on: October 26, 2008, 06:28:35 PM »
Yes you can still find it but you have to look first (or at least know how to look).
Bikebandit.com part # 227938-001 ~$23.00.
This means it's still available from Honda if Bike Bandit shows it's available which means if you get the Honda part number you can order online from ServiceHonda.com at a 30% discount. Get 2 while you're at it because it probably will not be available at a later date. If you don't use the 2nd one there's always someone else that will need it.
