Author Topic: bead blasting..  (Read 640 times)
Offline CaféElite
  • 1975 CB550
bead blasting..
« on: October 26, 2008, 05:41:10 PM »
I picked up a bead blasting cabinet at Harbor freight for #$%*s and giggles.. Having a hell of a time to get the glass stuff to come out at a consistant rate and I can also see a decent amount of water vapor as well. Using a super nice air compressor so I am mainly looking for advice on how to use this correctly..
Thanks!!
CB550's
Re: bead blasting..
« Reply #1 on: October 26, 2008, 06:36:14 PM »
I also have a Harbor Freight cabinet. Make sure you have a #$%*pot full of bead in the bottom of the cabinet and the pick up tube stays in said #$%*pot full. I live in a dry climate so I usually don't worry so much about moisture in my compressor since I don't paint with it BUT remember that as air is compressed so is the moisture in the air and it will settle/condense out. Be sure to pressure up the unit a small bit and open the drain valve. A "super nice air compressor" should be equipped with a condensor unit for the moisture vapor. You sure it's not broken down very fine bead that you are seeing?
Offline kirkn
Re: bead blasting..
« Reply #2 on: October 26, 2008, 07:22:28 PM »
I, too, have a Harbor Freight cabinet.  Their cheapest stand-alone model.  I haven't used glass beads in it yet, only sandbox sand from Home Depot.  Works like an absolute champ, but only if you keep it very full.  The more submerged the pick-up tube is, the better it works.  In fact, for a while, I didn't have enough in it, and it was erratic like you mention.  I finally just dumped more sand in it, and never had another problem.
I use a shop vac with it to help keep the dust down.  I aim the discharge of the shop vac well out of the garage and don't really have any dust control problems.  I still wear a cheap painters dust mask, just as kind of cheap insurance against breathing the sand dust, which, I guess can cause silicosis, a lung problem.
Uses more air than my compressor can provide.  That is, I have to stop and let my compressor catch up.  Still, mine does a great job.
I get moisture in mine, too, so I use a moisture separator in the line.  Works like a champ, too.  No more moisture.
Sorry I don't have any more helpful advise.  I guess I'd try filling it up more...
