Author Topic: One More Chapter in the Epic Story That is "THE PHOENIX"  (Read 70572 times)
« on: October 28, 2008, 10:48:34 PM »
so some may have seen earlier threads were i was kicking around how exactly to degree the cam of a 550 ("i heart megacycle")
so finally figuring out how its (suppose to be) done. i started kicking around other ideas of things to do while the motor is out and open (again)
  read alot of threads on boring, porting ,big bore, cam advance,and so on
jonsey's 550 porting thread
gentleman's express article
those were the most helpful , and of coarse the "thoughts of hondaman" in the Faqs
i'm not totally sold on punching out the jugs, i would love to do it but its strictly a money issue, first thing is the head
this is my first attempt at porting and its not done yet ... it's late and i'm tired
before
during
haven't done the final stage yet , i was too tired and getting sloppy
oops   :-[  guess i'll be gettig a valve guide ...Doh
« Last Edit: November 02, 2008, 10:45:40 AM by spikeybike »
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: One More Chapter in the Epic Story That is "THE PHOENIX"
« Reply #1 on: October 29, 2008, 01:43:10 AM »
Think of it this way.... at least you noticed it BEFORE you put it back together!!!
Glad to see the bike is rising from the ashes.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline kghost
« Reply #2 on: October 29, 2008, 10:58:16 AM »
Lotsa work there...looking good  8)
Stranger in a strange land
« Reply #3 on: October 29, 2008, 12:11:59 PM »
SNIP
May want to ask around. On the head for my CB750 project the machinist tapered the guides into the porting process. Of the part that hangs into the port, all 4 of my intake guides have been worked on. Maybe that's OK in your case too, unless you cracked it or such.
Now that i think of it, he just took a little meat off the sides of the guides, none off of where the sideload of the valve might be, that's where your touch appears to be.
« Reply #4 on: October 29, 2008, 01:22:09 PM »
Taking some of the guide off doesn't necessarily mean you need a valve job. I've ground the exposed part of the guide right off many times. I've posted a pic for an example
« Last Edit: October 29, 2008, 01:27:48 PM by MRieck »
« Reply #5 on: October 29, 2008, 01:25:09 PM »
Taking some of the guide off doesn't necessarily mean you need a valve job. I've ground to exposed part of the guide right off many times. I've posted a pic for an example
Cool! It may be many years, but you'll get my next business.
« Reply #6 on: October 29, 2008, 01:29:00 PM »
Thanks MC....hopefully I won't be going anywhere. ;)
« Reply #7 on: October 29, 2008, 05:29:08 PM »
cool! thats a relief ,
Offline BlindJoe
« Reply #8 on: October 29, 2008, 06:24:45 PM »
So, would you recommend doing the same on a 550 head? I did the same thing Spikey, they're hard to avoid with the bigger bits.
« Reply #9 on: October 30, 2008, 12:59:13 PM »
so does any one know if aftermarket valves for the 550 even exist , all i can find is stock valves
dynoman=no
kimblewhite=nope
just stock repros from DSS
« Last Edit: October 30, 2008, 01:00:46 PM by spikeybike »
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #11 on: October 30, 2008, 03:07:21 PM »
I recall seeing those valves in another thread as well. They're very nice valves, I'm tempted to pick some up... They're not that much more than going with Honda valves either, so it definitely wouldn't hurt to go with those.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline moham
  • .fnord.
« Reply #12 on: October 30, 2008, 03:11:41 PM »
Here is the thread of which you speak...
http://forums.sohc4.net/index.php?topic=42432.0
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
« Reply #13 on: October 30, 2008, 03:53:11 PM »
http://cgi.ebay.com/ebaymotors/HONDA-SOHC-CB500-CB550-OVERSIZE-VALVES-INTAKE-EXHAUST_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c39Q3a1Q7c66Q3a2Q7c65Q3a12Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem250315152437QQitemZ250315152437
He's one of us, just can't remember his name off hand, he custom makes them...he has a thread, CB550 head job maybe?
man those are pretty ... so mike, know anyone who would buy my arm or leg  ;D
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #14 on: October 30, 2008, 05:45:19 PM »
Once you sell your arm and leg, would you want to buy mine to replace them with? ;)
1977 CB550K
1979 CX500
« Reply #15 on: October 30, 2008, 07:29:59 PM »
Keep in mind those valves are 1mm oversize.
Offline HavocTurbo
  • Can you tell?
« Reply #16 on: November 01, 2008, 12:18:09 PM »
Well if its already apart... and ground up.... Might as well go for it!!!
09 XL883L - No Name
« Reply #17 on: November 01, 2008, 05:02:53 PM »
before
now some may be wondering why i haven't removed any of the old paint, normally that is one of the first steps ....  but i thought having the paint there would make it a little easier  to do this.
man my wrists are killin me
Offline HavocTurbo
  • Can you tell?
« Reply #18 on: November 01, 2008, 10:19:10 PM »
My neighbor used a belt sander and fine grit paper to do the fins on his DR650. If I were to do that I'd sand em smooth.... lol.
Looks great!!!
09 XL883L - No Name
« Reply #19 on: November 01, 2008, 10:43:29 PM »
i used an angle grinder with a fine grit flap wheel, then a scotchbrite type wheel, then the polishing wheels on the bench grinder , wasn't that hard
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #20 on: November 02, 2008, 09:44:26 AM »
Nicely done Spike  8)
..I was gonna say what Mike said about the valve guide. Mine are cut down on the intake side on my 350F, but it has a much smaller port.....or at least it did  ;)
If you've read the other forums than you know not to go too smooth on the intake ports to allow for a bit of turbulence for mixing. It looks like those intake runners are about right to me  8)
Are you going with heavier valve springs too?
 Matt.
« Last Edit: November 02, 2008, 12:02:03 PM by mattcb350f »
Gallery at:
« Reply #21 on: November 02, 2008, 10:44:58 AM »
 Matt.
yes, from megacycle
Offline kghost
« Reply #22 on: November 02, 2008, 12:28:49 PM »
Very cool....
Your killing me...I'm between projects sigh  ::)
« Reply #23 on: November 02, 2008, 12:52:00 PM »
Very cool....
yeah i ran out of projects ;D and had this head laying around my garage . so i said to myself "yeah, you might as well"   ;D ;D
now i definitely gotta take the jugs off to at least polish the fins
« Reply #24 on: November 04, 2008, 10:23:46 PM »
so when i polish the intake valves, do i want to go all the way to a mirror finish , or am i just smoothing out any imperfections in the metal.
