so my roommate and i where talking about my bike over beers, and he said something along the lines of "do you even know all the stuff you've done, you should try to make a tech sheet like in the magazines"
then i thought ...hmmm thats not a bad idea, so i did , now i will share it with the group
FRAME
1975 CB550F
notched for air filters
many custom ornamental brackets and mounts
ignition relocated
all welds smoothed and molded
ENGINE
barrnett clutch plates and springs
megacycle cam (126-01)
megacycle valve springs
slotted cam sprocket
NOS valves
NOS rocker arms and cam chain
Ported head (done by me)
Mac exhaust w/ unmodified baffle
DynaS electronic ignition
Dyna 5ohm coils and wires
NGK Iridium spark plugs
polished stainless allen head case screws
CARBERATION
stock Keihin - re-jetted
110 main jets, needle second from the bottom, air srews 1 3/4 turns out
K&N air filters
BODY
tapered steering stem bearings
chrome headlight and visor
hand made tail light mount
hand hammered and molded gas tank
formed sheet metal seat/tail section
rear fender moved in 3"
lowered rear end 2"
every piece of aluminum was polished
chrome colony spike hardware
BRAKES
Goodridge stainless steel lines
chrome banjo fittings
phenolic brake piston
drilled rotor
drilled drum
HANDLE BARS
drag style 7/8"
chrome levers
rubber grips
SUSPENSION
MDI/Forsa Shorty shocks
Progressive Suspension fork springs
Bel-Ray 10w fork oil
GAUGES
NOS chrome backing plates
chrome gauge covers
hand laid digits and lettering
needles polished
LIGHTING
J&P cycles turn signals
J&P cycles halogen headlight
Custom Chrome halogen tail light
WHEELS & TIRES
stock NOS wheels
All Balls bearings
Dunlop 404 front 100/90-19
Dunlop 404 rear 110/90-18
and i was out snapping photo's yesterday, testing different settings on my camera, so i'll share those too
