Author Topic: IRC Tires, any good?  (Read 10153 times)
Offline GroovieGhoulie
  • I have to return some videotapes.
« on: October 29, 2008, 10:48:21 AM »
What's the word on these tires?  I've only used Avons, Dunlops and Metzeler on my old Hondas, and I just found out that IRC is one of the only, (maybe THE only), tiremaker that makes tires in the appropriate size for my NS400R:
F: 100/90-16
R: 110/90-17
Model is RS-310 DuroSport "Sport Touring" tires.
The fronts are easy, but NO ONE makes a 110/90-17 rear.
Good buys, or crap?
eldar
Re: IRC Tires, any good?
« Reply #1 on: October 29, 2008, 11:09:35 AM »
« Reply #2 on: October 29, 2008, 11:14:06 AM »
Dude, you win the thread.
I checked like a million other online vendors, (well, six), and none had the BT45 in 110/90-17.  They all had the appropriate front, but not the rear.  That solves it.
Thanks!!!!!
eldar
« Reply #3 on: October 29, 2008, 12:16:50 PM »
No problem ;)
Offline 333
  • Time for change
« Reply #4 on: October 29, 2008, 12:48:02 PM »
And you'll be much happier with those.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
« Reply #5 on: October 29, 2008, 12:57:48 PM »
I would agree, but I have no firsthand knowledge of IRC quality. They are a huge manufacturer, capable of making a premium product, so I hope others chime in.
I bought a IRC "dummy" rear for my project to see if various things would fit, just cause it was cheap, but i would like to know if others think they are good tires.
Offline Uncle Ernie
« Reply #6 on: October 29, 2008, 01:16:54 PM »
IRC is fair.  Sort of like Ching Shens.
They're off-road tires are better.  I wouldn't use IRC for track days, but they'll get you around OK.  They won't last as long as the BT45's.
Offline 333
  • Time for change
« Reply #7 on: October 29, 2008, 01:30:07 PM »
But the speed rating says it all.  And before you say that you don't need a tire rated at 110 or 130, the higher speed rated tires have benefits at 55.  It means a cooler tire at 55, and that translates into a tire that you will get more miles out of.  Without sacrificing traction.
Offline Uncle Ernie
« Reply #8 on: October 29, 2008, 01:34:00 PM »
Not so sure about that...
It's been a long time, but I seem to remember that tires get a higher rating because they have less rubber (less weight).
Somebody hep me here-?
Offline 333
  • Time for change
« Reply #9 on: October 29, 2008, 01:43:58 PM »
You are correct.  Less weight=less mass being spun around=less heat.  They achieve this by getting a higher ply rating than there are actual ply's.  You'll see "6 ply rating" where it may only be 4 ply tire.  This also allows a softer rubber(more traction) without sacrificing too much tire life.
Offline mrblasty
  • Expertly
« Reply #10 on: October 29, 2008, 01:49:30 PM »
I have used the IRC Durotour tires for a while now, it rained a lot of the time time i was riding in Oregon so I was looking for a sticky tire and they fit the bill.  They do wear quick but I have only felt the m slip on wet manhole covers, and yes I did say manhole.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
eldar
« Reply #11 on: October 29, 2008, 01:51:31 PM »
You like the manhole! :D
Offline 333
  • Time for change
« Reply #12 on: October 29, 2008, 02:00:22 PM »
The politically correct word is "personhole". ;D ;D ;D
« Reply #13 on: October 30, 2008, 05:07:25 AM »
I'm probably gonna order from the posted site, even though their prices are a little high.  Most places have the 100/90-16 front around $83 or so and they're charging $117.  The rears are probably the same, but if they're the only game in town...
I might just order the rear and get the front somewhere else.
That did solve a big problem though.
eldar
« Reply #14 on: October 30, 2008, 06:11:07 AM »
I did a google just using the tire size. Try that and you might find another dealer that is cheaper.
