Author Topic: Help changing to diff wheels 1978 Cb750K  (Read 7457 times)
stickitgraphic
« on: September 21, 2005, 11:27:06 PM »
Hello, I have a 1978 Cb750K. I have have lowerd and strecthed it 6 over. I am looking to change these spokes to something more flashy. I need to know what front ends will bolt right up and maybe some that need a little mod. I have a brake drum in back and I may have to change it to disk. I would like to stay 16" in the back and maybe 19" in the front.
  Is there any bolt on front wheels or front ends or any bolt on rear wheels? I need some help and maybe a bunch of ideas to work with. Thanks alot Kyler T.
Offline Lumbee
    • My pics...
Re: Help changing to diff wheels 1978 Cb750K
« Reply #1 on: September 22, 2005, 07:26:16 AM »
sup stick...check this out for wheels...  http://cyclexchange.net/Wheel%20Page.htm .  Also, there was a good post a few weeks back where somebody listed like 20+ sport bikes that shared common neck sizes with the 750.  I looked, but couldn't find it.  If someone remembers the post, please post  a link...
"I'm not a welder, but I play one on HondaChopper.com"
stickitgraphic
« Reply #2 on: September 23, 2005, 04:24:26 AM »
I really like those Invader Mags ouch on the prices. Maybe thats good I will be shopping this winter. I think those will set my bike off THANKS ALOT.. Kyler
« Last Edit: September 23, 2005, 05:09:53 AM by stickitgraphic »
Offline dusterdude
« Reply #3 on: September 23, 2005, 05:54:33 AM »
kyler,did you lengthen the swingarm,because the shocks appear to be laid down a bit.looks good,how did you do it?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Geeto67
  • A grumpy
« Reply #4 on: September 23, 2005, 11:23:21 AM »
I hear a lot of people have success swaping cbr f2 and f3 rims on their bikes. For the cbr front end you have the cbr stem knocked out of the triple trees and a machinist put a cb750 stem in it's place (and weld it in). The cbr rims take the same axle size as a cb750 but if you use them with your existing hardware you will need custom spacers made. I think you can get away with an f2 rear rim in your stock swingarm but will need custom spacers, cbr f2 rear brake setup, and to weld the brackets to the swingarm for the brake locating arm. You will also need a way to hook up your pedal to the rear master cylinder. Since cbr parts are plentiful in salvage yards you should be able to score the parts you need fairly cheap. I also like the fzr400 rear rim as a starting point but those are harder to find and require a lot more work.
Invadiers are heavy, not sure if you are going with the drag bike look or actually want the weight savings to go along with it.
BTW nice digger style bike.
Maintenance Matters Most
Offline hahnda
  • lskdfhs;dljksa;
« Reply #5 on: September 23, 2005, 12:08:11 PM »
All these bikes share the same upper and lower stem diameters. This does not mean that they are a direct swap since stems vary in length. Other problems could pop up also. It is a list to research to see what might work for ya. Some might be a direct bolt on like the early GL1000.
Kevin
Upper: 26 x 48.5 x 15.2
Lower: 30 x 50 x 14.4
Honda C250N (79)
Honda CB250 (Early Models)
Honda CB250RS (80-84)
Honda CBX250RS
Honda CM250T Rebel (82-84)
Honda GB250F/F2
Honda MVX250 (83-84)
Honda VT250F (83-86), VTR250 (88)
Honda CB350F/F1 (73-74), CB350G (73), CB350/ K2-K4 (69-72)
Honda SL350 /K2/K3 (69-73)
Honda CB360 (74-76), CB360GT (76), CB360T (74-77)
Honda CJ360T (76-77), CL360 (74-75)
Honda CB400A (74-75), CB400F (75-77), CB400TI/TII (78-79), CB400T (80-81)
Honda CBX400F
Honda CM400A/C/E/T (79-81)
Honda GB400
Honda CB450/K1-K7 (65-74), CB450T (82), CB450SC (82-86)
Honda CL450 /K2-K6 (68-74)
Honda CM450A/C/E (82-83)
Honda CB500/K1/K2 (71-73), CB500T (75-76)
Honda CX500 C/D (78-81)
Honda FT500 Ascot (82-83)
Honda GB500F/F2
Honda GL500/I (81-82)
Honda VT500 Ascot (83-84), VT500ED, VT500C/FT (83-84)
Honda CB550K/K1 (74-78), CB550F (75-77), CB550SC (83)
Honda CBX550F (82-83)
Honda CB650 (79-82), CB650C (80-81), CB650SC (82-85), CBX650ED/SCD
Honda CX650C (83), CX650ED
Honda GL650/I (83)
Honda VT700C (84-85)
Honda CB750K (69-78), CB750A (76-78), CB750F (75-78)
Honda VFR750C (83)
Honda VT750C (83)
Honda GL1000 (75-76)
Honda GL1000L (76)
Upper: 26 x 47 x 15
Lower: 30 x 55 x 17
Honda NSR250R/F
Honda VTR250 (89-91)
Honda CBR400R (87)
Honda CBR400 R/R
Honda NS400RF/RG (85-86)
Honda VFR400ZG/RG
Honda CMX450C (86-87)
Honda CX500TC (82)
Honda VF500C (84-85), VF500F (84-86), VF500FE/FIIE/FF
Honda VT500C (85-86)
Honda CBR600 (89-90)
Honda CBR600F (87-90), CBR600 FM-FR (91-97), CBR600H
Honda VT600CJ (87), VT600C N-R (92-94)
Honda VT600C/CD Shadow VLX (88-97
Honda CX650T (83)
Honda NT650 (88-89)
Honda NT650J Revere
Honda CB700SC (84-86)
Honda VF700C (84-87)
Honda VF700F/S (84-85)
Honda VFR700F/F2
Honda CB750C/F/K (80-82)
Honda CB750F N-S (92-95)
Honda CB750FA/FB/FC/ F2C
Honda CB750SC (84-85)
Honda CBX750FE/F2F (84-86)
Honda VF750C (82-83)(88)
Honda VF750CC/CD/CE/SC/SD
Honda VF750F (83-84)
Honda VF750 F D/E/F (83-85)
Honda VF750FD
Honda VF750S (82-83)
Honda VFR750 (90-93)
Honda VFR750F/F2 (82-87), VFR750F L-S (90-95)
Honda VFR750FG/FH/FJ/FK/ FL
Honda VT800 (88-89)
Honda VT800C Shadow(88)
Honda PC800 Pacific Coast (89-98)
Honda CB900C (80-82), CB900F A/B/2B/C/2C (80-82), CB900FS(94)
Honda CBR900RR (93-98)
Honda CB1000C (83), CB1000F S (95)
Honda CBR1000 (87-93)
Honda CBR1000F (87-88)(90-96)
Honda CBX B/C (81-82)
Honda VF1000F (84-85), VF1000FE/FF/F2F, VF1000R (85-86)
Honda GL1100 (80-83), GL1100C/AC/DC/IC, GL1100D2D/AD/A/IA/DA, GL1100RB/RC/D/ID/DD
Honda VF1100C (83-86), VF1100S (84-85)
Honda VT1100C (85-89), VT1100C R-S (94-95)
Honda GL1200 (84-87)
Honda GL1500 (88-91)
Honda GL1500 AP-AR (93-94)
Honda VTX1800C (02)
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline Lumbee
    • My pics...
« Reply #6 on: September 23, 2005, 03:23:36 PM »
...thats the list...
« Reply #7 on: September 23, 2005, 03:31:45 PM »
Thats the list to end all lists. ;D ;D ;D
Offline hahnda
  • lskdfhs;dljksa;
« Reply #8 on: September 23, 2005, 05:18:17 PM »
Wanna sse the whole list for all sizes?
Kevin
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline Lumbee
    • My pics...
« Reply #9 on: September 23, 2005, 06:02:03 PM »
...give it up Ha...
Offline hahnda
  • lskdfhs;dljksa;
« Reply #10 on: September 23, 2005, 06:31:37 PM »
Upper: 22.5 x 41 x 12.5
Lower: 24 x 41 x 12.5
Honda MB-5-50 (82)
Honda MR-50/K1 (74-75)
Honda MT50Z, MTX50
Honda NSF50F (90)
Honda Z50A/K3-K5/RH/RJ, Z50A (71-76)
Honda Z50R (79-87), Z50RD (86)
Honda CR60R (83)
Honda ATC70/K1 (73-74), ATC70 (78-85)
Honda CL70/K1-K3 (69-73)
Honda CT70/K1-K4 (69-76), CT70H/HK1 (70-73), CT70 (76-82)
Honda SL70/K1 (71-73)
Honda XL70 (74-76)
Honda XL75 (77-79)
Honda XR75 (73-78)
Honda MB80, MBX80RFD/RSD
Honda MTX80/C
Honda XL80S (80-85)
Honda XR80 (79-84), XR80RF-R (86-98)
Honda ATC90 (75-85)
Honda CS90
Honda CT90 (68-79)
Honda SL90 (69)
Honda ST90K1-K4
Honda CB/CL100/K1-K3 (76-78)
Honda SL100/K1-K3 (70-73)
Honda XL100/K1 (74-75), XL100/S (76-85)
Honda XR100RP-R (85-98)
Honda ATC110 (79-85)
Honda CT110 (80-86)
Honda XL110/S (76-85)
Honda ATC125M (84-87)
Honda CB125/S (76-85), CB125T/J (78-81), CB125TT (90)
Honda CG125
Honda CM125T/J (82-85)
Honda CR125M/M1 (74-78)
Honda CT125 (77), CT125H/J/K (87-89)
Honda MBX125
Honda MT125 (74-76), MT125R/RII (77-78)
Honda SL125/K1/K2
Honda TL125/K1/K2/S (73-76)
Honda XL125K-3 (78-79), XL125S (79-85)
Honda MR175K (75-77)
Honda ATC185/S (80-83)
Honda CM185C (78), CM185T (78-79)
Honda XL185S (79-83), XL185SH/SJ/SK
Honda XR185 (79)
Honda ATC200 (79-83), ATC200E Big Red (82-84), ATC200S (84-85)
Honda CM200T (80-82)
Honda XR200 (80-83)
Honda CB250N (Late Models)
Honda CBX250F (85)
Honda CM250C (82-86), CM250T (80-82), CMX250C/CD (85-87)
Upper:30 x 55 x 17
Lower: 30 x 55 x 17
Suzuki GSXR600 (97-00)
Suzuki GSXR750 (96-01)
Suzuki TL1000R (98-00)
Suzuki TL1000S (97-01)
Suzuki GSXR1300R (99-00)
Yamaha YZFR6 (99-01)
Yamaha YZF-R1 (99-00)
Upper: 25 x 47 x 15
Lower: 30 x 55 x 17
Honda CB750KZ/FZ
Honda CB900FZ
Honda CBX/Z
Honda GL1000 (77-79), GL1000K3/Z
Kawasaki KX125 (82-91)
Kawasaki KDX200 (83-98)
Kawasaki KX250A5-A7(79-81), KX250B1/C1/C2/D1/D2/E1/F1/G1/H1/H2 (82-91)
Kawasaki KXT250A1/A2/B1/B2 (84-87)
Kawasaki KDX420B1 (81)
Kawasaki KX420A1/A2 (80-81)
Kawasaki KDX450A1 (82)
Kawasaki EX500B1-B4 (88-91)
Kawasaki KX500A1/A2 (83-86) B1/B2 (85-86), C1/D1 (87-88), E1-E3/E4/E5 (89-93)
Kawasaki ZG1200B1-B12 Voyager (87-98)
Suzuki DR125SER/SES/SET/SEV (94-97)
Suzuki RM125J
Suzuki PE/RS175T-E (80-84)
Suzuki DR200SET/SEV/ SEW (96-98)
Suzuki DR250 (90-91), DR250S L/M/N/P/R /SES (90-95)
Suzuki GN250Z/D/F (82-85), GN250Z-ER (81-95)
Suzuki GSX250F M/N/P/R (91-94)
Suzuki PE250T/X (80-81)
Suzuki RG250G/FG (85)
Suzuki RGV250K (88-89), RGV250M/N/P/R (91-94)
Suzuki RM250J (88)
Suzuki RS250T/X (80-81)
Suzuki DR350 (90-98)
Suzuki DR350S L-HR (90-94)
Suzuki DR350SL/SM/SN/ SP/SER/SES/SET/SEV/SEW (90-98)
Suzuki DR400T (80) DR400ST
Suzuki GN400 (80), GN400T/TX/TZ (80-82)
Suzuki GSF400M (91-93), GS400 Bandit (91-93)
Suzuki GSX400EE/SE/EF/SF (85), GSX400ET/ST/EX/ SX/X
Suzuki GSXR400F
Suzuki PE400T/X (80-81)
Suzuki GS450E T/X/Z/D (80-83)
Suzuki GS450G Z/D/F(82-85), GS450L (80-88)
Suzuki GS450TX/TXZ/TXD/TZ (81-83)
Suzuki DR500X/Z/D (81-83)
Suzuki DR/PE500T/X (80-81)
Suzuki GS500E/EK/EV (89-00), GS500L (80-83)
Suzuki RG500G
Suzuki SP500X/Z (81-82)
Suzuki GS550E (83), GS550EF (85), GS550ESE/ESF (84-86), GS550ESG (86)
Suzuki GS550ET (80), GS550L (80-83), GS550LF/LG (85-86), GS550MZ (82), GS550TX (81)
Suzuki GSF600 (1996-00)
Suzuki GSX600FJ-FW (88-01)
Suzuki GSXR600WN/WP (92-93)
Suzuki RF600R (P/R) (93-94), RF600RR/RS /RT (94-96)
Suzuki DR650RE R/UR (94)
Suzuki DR650SN/SP (92-93)
Suzuki GS650D/XD (83), GS650EX/EZ (81-82), GS650GL (81-83), GS650 GX/GZ/ GD (81-83), GS650 MD (83)
Suzuki LS650F/P/G/J/K, LS650PS/PT/PV/PW Savage (95-01)
Suzuki NX85D (83)
Suzuki SV650  (99-00)
Suzuki GS700EF/ESF (85)
Suzuki GV700GLF (85)
Suzuki VS700 (86-87)
Suzuki DR750S/SU/J/K
Suzuki GS750ED/ESD (83), GS750ET/EX/EZ (80-82),GS750LT/LX (80-81), GS750SD (83), GS750TZ/TD (82-83)
Suzuki GSX750EF/F (85), GSX750ES D/E (83-84), GSX750F(89-92), GSX750FK-FT (89-96), GSX750S S/D (83)
Suzuki GSXR750 (86-95), GSXR750W N/P/R
Suzuki 750T/X (81-82)
Suzuki VS750G (88-91)
Suzuki VS800GLN-GLT Intruder (92-01)
Suzuki VX800L/M/N/P (90-94)
Suzuki VZ800V/W Marauder (97-01)
Suzuki GS850G/GL (79-83)
Suzuki RF900RR/RS/RT/ RV (94-97)
Suzuki GS1000C/EC/HC/N (78-79), GS1000ET (80), GS1000G/GL (80-81), GS1000L N (79)
Suzuki GS1000LN/SN/ST (79-80), GS1000SZ (82), GS1000T/HT/ ET (80)
Suzuki GS1100E (80-83), GS1100G/GL(82-83), GS1100GK (82-84), GS1100LT (80), GS1100SD (83)
Suzuki GSX1100E/ES/EF, GSX1100E T/X (80-81)
Suzuki GSX1100EE/ESF/EFF/EF/ESF/EFF (84), GSX1100F (90-93)
Suzuki GSX1100FJ-FP (88-93), GSX1100G M/N/P/R (91-94)
Suzuki GSX1100LT/ST (80), GSX1100 LN/SN (79), GSX1100S Z/D (82-83)
Suzuki GSXR1100 (90-93), GSXR1100F (88-92), GSXR1100G-M (86-91), GSXR1100WP/WR/ WS/WT/WV (93-98)
Suzuki GS1150EF/EG (85-86), GS1150ES3/ESE/ ESF (83-85)
Suzuki GSX1150E (83-86)
Suzuki GSF1200SV/SAV (97-01)
Suzuki GV1200GLF/GLG (85-86)
Suzuki GV1400G (86-89)
Suzuki VS1400 (87-01)
Suzuki VS1400GL H/R (87-01)
Suzuki VL1500 (98-01)
Yamaha BW80S/T/U/A (86-90)
Yamaha YZ100J/K (82-83)
Yamaha YZ125D-S (77-86)
Yamaha IT175D-K (77-83)
Yamaha IT200L/N/S (84-86)
Yamaha IT250D/E/F/G/H/J/K (77-83)
Yamaha TZ250F/G/H/J (79-82)
Yamaha TZR250R
Yamaha XT250L/LC (84)
Yamaha YZ250D-T (77-87)
Yamaha TT350S/T (86-87)
Yamaha XT350N/NC-K/KC (85-98)
Yamaha IT400D/E/F (77-79),
Yamaha FZR400 (88-90)
Yamaha YZ400D/E/F (77-79)
Yamaha IT425G (80)
Yamaha IT465H/J (81-82), YZ465G/H (80-81)
Yamaha IT490K/L (83-84), YZ490J-A (82-90)
Yamaha RZ500N (85)
Yamaha XT550J/K (82-83)
Yamaha FZR600 (89-99)
Yamaha TT600L/N/S/T/U (83-88)
Yamaha XT600L/LC-G/GC (84-95)
Yamaha YZF600 (95-00)
Yamaha XV650 (98-01)
Yamaha FZ700T/TC (87), FZX700S/T/TC (86-87)
Yamaha XJ700N/NC/S/SC/XN/XS/XSC (85-86)
Yamaha XV700 Virago (84-87)
Yamaha FZ750N/S/SC (85-86), FZ750U/UC (88)
Yamaha FZR750RT/RU (87-88), FZR750R (90), FZX750 (87-89)
Yamaha XS750 ALL (77-79)
Yamaha XTZ750 (93)
Yamaha XV750 Virago (88-97)
Yamaha YZF750 (94-98)
Yamaha XS850 ALL (80-81)
Yamaha TDM850 (92-93)
Yamaha XJ900RK (83), XJ900FN (85)
Yamaha FZR1000 (87-91), FZR1000 EXUP (83-95)
Yamaha XV1000 Virago (84-85)
Yamaha FJ1100 (84-85)
Yamaha XJ1100J (82)
Yamaha XS1100ALL (78-81)
Yamaha XV1100 Virago (86-97)
Yamaha FJ1200 (86-91)
Yamaha VMX1200 V-Max (85-97)
Yamaha XVZ1200 Venture (83-85)
Yamaha XVZ1300 Venture (86-93)
Yamaha XVZ13 Royal Star
Upper: 25 x 48 x 16
Lower: 27 x 48 x 14
Suzuki RM125A/B/C (75-78)
Suzuki PE175C/N (78-79)
Suzuki GS250FW (85)
Suzuki GSX250T/ET (80)
Suzuki GT250A/B (76-77)
Suzuki PE250C/N (78-79)
Suzuki RM250A/B/C/C2
Suzuki TM250K/L/M (73-75)
Suzuki TS250 (70-79)
Suzuki GS300LF/LZ/LD (82-85)
Suzuki RM370A/B/C (76-77)
Suzuki SP370 (78-79)
Suzuki GT380K-B (73-77)
Suzuki GS400B/C/EC (77-78)
Suzuki RM400C (78)
Suzuki SP400T (80)
Suzuki TM/TS400 (73-77)
Suzuki GS425N/EN (79)
Suzuki GT500A/B (76-77)
Suzuki RE-Rotary (75-76)
Suzuki GS550B/C/EC (77-79)
Suzuki GT550J-B (72-75)
Suzuki GS750B/C/EC/N (77-79), GS750D C/N (78-79), GS750EN/ LN/LT (79-80)
Suzuki GT750 (72-77)
Upper: 25 x 48 x 13
Lower: 30 x 48 x 13
Suzuki RM100N/T/X (79-81)
Suzuki RM125N/T (79-80)
Suzuki RM250N/T (79-80)
Suzuki RM400N/T (79-80)
Yamaha L5T/L5TA-100 (69-70)
Yamaha RD125B/C (75-76)
Yamaha RD125LC
Yamaha TA125 (Roadrace)
Yamaha TD2/TD2B125 (70-71)
Yamaha TR2/TR2B125 (70-71)
Yamaha TZ125G (Roadrace) (80)
Yamaha YB125E/F
Yamaha RD200A/B/C (74-76)
Yamaha YTM200N/ERN (84)
Yamaha YTM225DRN/DRS (85-86)
Yamaha YTM225DXL/DXN (84-85)
Yamaha FZR250
Yamaha RD250 /LC (73-82)
Yamaha RD250YPVS (83-84)
Yamaha SR250G/H/J/TH (80-82)
Yamaha SRX250N (85), SRX250T/TC (87)
Yamaha TD3/TR3-250 (Roadrace) (72)
Yamaha TZ250 (73), TZ250C/D/E (76-78)
Yamaha TZR250 (87-91)
Yamaha XS250
Yamaha XV250U-W (88-89), XV250A/AC (90), XV250G/GC/H/HC/J/JC (95-99)
Yamaha R5/B/C (70-72),RD350 (73-79), RD350LC (80-82)
Yamaha RD350YPVS (83-84), RZ350L/N/NC (84-85)
Yamaha TZ350C/D/E (74-78)
Yamaha XS360C/D/2D (76-77)
Yamaha RD400A/B/C/D (76-79)
Yamaha XJ400 (80-85)
Yamaha XS400E/F/2E/2F (77-79), XS400G/H/J/K (80-83), XS400RJ/RK (82-83), XS400SG/SH (80-82)
Yamaha XV500 (83) XV535 (87-99)
Yamaha XV535 (91-94), XV535H/N (89-90), XV535SE (88), XV535T/TC/U/A/ AC/EC/F/FC/G/GC/ SFC/SG/SGC/SH/SHC/SJ/SJC (87-97)
Yamaha XJ550H/J/K/RH/RJ/RK (81-83)
Yamaha FJ600L/LC/N/NC (84-85)
Yamaha XJ600 (92-98)
Yamaha YX600 (86-90)
Upper: 25 x 43 x 11
Lower: 30 x 48 x 12
Yamaha DT50B, DT50MX, DT50U/W/A (88-90)
Yamaha RD50MX (82), RX50K/L/MK (83-84)
Yamaha YSR50T-E (87-93)
Yamaha YZ50G (80)
Yamaha JT1/JT2/JT2MX (71-72)
Yamaha RD60/A/B (73-75)
Yamaha YZ60H/J/KM (81-83)
Yamaha DT80LC H/J/K (81-83), DT80MX
Yamaha GT80A-G (74-80), GT1/GTMX80 (73), GTMXA/MXB/MXC 80 (77-79), MX80G/H/J (80-82)
Yamaha RD80LC/MX(82)
Yamaha TY80A/B Trials (74-75)
Yamaha YZ80A-K (74-83)
Yamaha HT1/HT1B/HT1BM90 (70-71)
Yamaha AG100B
Yamaha DT100A-K (74-83)
Yamaha LT2/LT2M/LT2MX/LT3100 (72-73)
Yamaha MX100A/B (74-75)
Yamaha MX100F/H/J/K (79-83)
Yamaha RS100B/C (75-76)
Yamaha RT100A (90)
Yamaha YZ100C/D/E/F/G/H (76-81)
Yamaha AT1/AT1B/AT1C/ AT1E/AT1M/AT1MBAT1MX/AT2/AT2M/AT2MX/AT3/ 125 All (69-73)
Yamaha DT125 All (74-81), DT125LC (82)
Yamaha IT125G/H (80-81)
Yamaha MX125A/B/C (74-76)
Yamaha XT125J/K/KC (82-83)
Yamaha YT125N (85)
Yamaha YZ125A/B/C/X (74-76)
Yamaha AG175B
Yamaha CT1/CT2/CT3 175 All (69-73)
Yamaha DT175A-H (74-81)
Yamaha MX175A/B (74-75)
Yamaha MX175G/H/J (79-81)
Yamaha TY175B/C (75-76)
Yamaha YT175J/K Atv(82-83)
Yamaha YZ175C (76)
Yamaha SR185H/J (81-82)
Yamaha AG200
Yamaha BW200N/S/ES/ET/ EU (85-88)
Yamaha TW200 (87-92)
Yamaha TYM200EX/EL (83-84)
Yamaha XT200J/K/KC (82-83)
Yamaha YTM200K/EK (83), YTM200K/L (83-84)
Yamaha YTM225DXK (83)
Yamaha DT1/DT1B/DT1CMX/DT1MX/DT1S/ DT1C/DT1E/DT2/ DT2MX/DT250A-F/DT3 250 (68-79)
Yamaha MX250A/B (73-75)
Yamaha TT/XT250G/H/J (80-82)
Yamaha TY250A/C/D (74-77)
Yamaha XT250G/H/J/K/KC (80-83)
Yamaha XT250W (89)
Yamaha YZ250A/B/C (74-87)
Yamaha DT360A/B (74-75),
Yamaha MX360/A (73-74)
Yamaha RT1/RT1B/RTM/RT1MX360 (70-71)
Yamaha RT2/RT3/RT2MX360 (72-73)
Yamaha YZ360A/B (74-75)
Yamaha DT400B/C/D/E (75-78)
Yamaha IT400C (76)
Yamaha MX400B/C (75-76)
Yamaha YZ400B/C (75-76)
Yamaha SC500/A (73-74)
Yamaha SR500E/F/G/H (78-81)
Yamaha TT/XT500C-H (76-81)
Upper: 25 x 47 x 15
Lower: 28 x 52 x 16.5
Kawasaki KL250D2-D8 (85-91), KLR250 (-98)
Kawasaki ZX400K1/K2/K3
Kawasaki EN450A1-A7 (85-91), EN450N
Kawasaki EN500A1-A6 (90-96), EN500C1/C2 Vulcan Ltd (96-97)
Kawasaki GPZ550H1
Kawasaki KZ550F1/F2/M1 (83-84), KZ550H1/H2 (82-83)
Kawasaki Z550G6, Z550M1 Ltd (83)
Kawasaki ZR550B1-B5 (90-94)
Kawasaki ZX550A1/A2 (84-85)
Kawasaki GPX600R
Kawasaki KL600A1/B1/B3 (84-86)
Kawasaki ZX600 Ninja (85-97)
Kawasaki KLR650/B2 Tengai (89)
Kawasaki KL650A1-A11/B2/ KLR (87-97)
Kawasaki KZ700A1 (84)
Kawasaki ZN700A1/A2 (84-85)
Kawasaki GP750R, GPZ750R/R1
Kawasaki KZ750F1, KZ750L3 (83)
Kawasaki KZ750N1/N2 (82-83), KZ750R1 (82)
Kawasaki VN750A2 (86)
Kawasaki ZR750C1-C4 (91-94), ZR750 Zephyr
Kawasaki ZX750A1-A3/E1/E2/ F1-F4/H1/H2
Kawasaki GPZ900R
Kawasaki ZL900A1/A2 (85-86)
Kawasaki ZX900A1-A3 (84-86)
Kawasaki KZ1000J1-J3/K1/K2/ M1/M2 (81-82), KZ1000P1-P17 (82-98), KZ1000R1/R2 (82-83)
Kawasaki Z1000K1 LTD (82)
Kawasaki ZG1000A1-A9 (86-94)
Kawasaki ZL1000A1 (87)
Kawasaki ZX1000A1/A2 (86-87), ZX1000B1-B3 (88-90)
Kawasaki GPZ1100A/S, B/S (81-82)
Kawasaki KZ1100A1-A3 (81-83), KZ1100B1/B2 (81-82), KZ1100D1/D2 (82-83), KZ1100L1 (83)
Kawasaki Z1100J/J2/Z
Kawasaki ZN1100B1/B2 (84-85)
Kawasaki ZR1100A1/A2 (92-93)
Kawasaki ZX1100A1-A2 (83-84)
Kawasaki VN15SE
Kawasaki VN1500A1-A9 (87-95)
Kawasaki VN1500B1-B5 (87-91)
Kawasaki VN1500A10/A11/C3/C4/D1/D2 (96-97)
Honda C250N (79)
Honda CBX250RS
Honda GB250F/F2
Honda CBX400F
Honda GB400
Honda GB500F/F2
Honda GL650/I (83)
Honda VFR750C (83)
Honda VT750C (83)
Honda GL1000L (76)
Upper: 30 x 48 x 14
Lower: 30 x 48 x 14
Kawasaki KH250A5 (76)
Kawasaki KZ250A
Kawasaki EX350B1 (83)
Kawasaki KZ350A1/A2/B1 (81-82), KZ350B2/B3 (87-88)
Kawasaki KH400A3-A5 (76-78)
Kawasaki KZ400A1/A2 (77-78), KZ400B1/B2/C1 (78-79)
Kawasaki KZ400D/D3/D4 (74-77), KZ400H1 (79), KZ400S/S2/S3 (75-77)
Kawasaki ZX400D1-D5 (80-83)
Kawasaki KZ440A1-A4/D1-D5 (80-83), KZ440B1/B2 (80-81)
Kawasaki H1 500 C/D/E/F (69-75), KH 500A8 (76)
Kawasaki KZ500 (69-73)
Kawasaki H2 750 A/B/C (72-75)
Upper: 30 x 48 x 14
Lower: 30 x 52 x 17
Kawasaki EL250B2/B3 (88-89), EL250E1/E2 (91-92), EL250D4/D5 (93-94)
Kawasaki EX250E/E2/F2-F4 (86-90), EX250 F6/F7/F8/F9,F10/ F11 Ninja250R (92-97), EX250 H1-H5 (90-94)
Kawasaki ZX400H1/H2, ZXR400R
Kawasaki EX500A1-A7 (87-93), EX500D1-D4 (94-97)
Kawasaki KZ550A1-A4/C1-C4 (80-83), KZ550D1 (81)
Kawasaki KZ650B1-B3/C1-C4/D1/D2/E1/F1/H/ H1-H3
Kawasaki KZ750B1-B4 (76-79), KZ750E1-E3 (80-82)
Kawasaki KZ750G1 (80), KZ750H1-H4(80-83), KZ750K1/K2 (83-84), KZ750M1 (82), KZ750T
Kawasaki KZ900A4/B1 (76)
Kawasaki Z1 900A/B (73-75)
Kawasaki Z1R Series (78-80)
Kawasaki KZ1000A1-A4/B1-B4 (77-80), KZ1000D1 (78), KZ1000D3/G1 (80)
Upper: 25 x 48 x 15.2
Lower: 30 x 48 x 15
Yamaha FZR400R
Yamaha SXR400
Yamaha SX500B/C/D/E (75-78), TX500/A (73-74)
Yamaha XS550RK/RJ (82-83), XZ550RK/RJ (82-83)
Yamaha FZ600 (86-88)
Yamaha SRX600S/SC (86), SRX600T
Yamaha TX650/A (73-74)
Yamaha XJ650G/H//J/K (80-83), XJ650LH (81), XJ650LJ/LK/RJ (82-83)
Yamaha XS6501/1B/XS2 (70-72), XS650B-H/2F (75-81), XS650SE-SH (78-81), XS650SJ/SK (82-83)
Yamaha TX750 (73-74)
Yamaha XJ750J/K/MK/RH/RJ/RK (81-83)
Yamaha XV750H/J/K/MK (81-83), XV750SE (82)
Yamaha XV920J/K/MK (82-83), XV920RH/RJ (81-83)
Yamaha XV1000K/L Virago (83-84)
Upper: 26 x 47 x 15
Lower: 30 x 55 x 17
Honda NSR250R/F
Honda CBR400R (87)
Honda CBR400 R/R
Honda VFR400ZG/RG
Honda CX500TC (82)
Honda CX650T (83)
Honda NT650 (88-89)
Honda NT650J Revere
Honda VFR700F/F2
Honda VF750FD
Honda VT800 (88-89)
Honda VTX1800C (02)
Upper: 26 x 47 x 15
Lower: 26 x 47 x 15
Honda CR80RL-RR (90-94 )
Honda CR125R (82-89)
Honda NX125 (88-90)
Honda XL200R (83-84)
Honda XR200R (81-87), XR200RE/RF/RG/RH/RJ
Honda ATC250R (83-86)
Honda CR250R (82-89), CR250RE/RF/RG/RH/RJ/RK
Honda XL250R (82-87), XL250R E/F (84-85), XL250R J/K/L (88-90)
Honda XR250RE/RF/RG/RH/RJ/RK, XR250R N-R (92-94)
Honda XL/XR350R (83-85)
Honda XR350RD/RE/RF/RG/RH/RJ/RK
Honda XR400R (97-98)
Honda CR450R (81)
Honda CR480R (82-83)
Honda CR500R (84-89)
Honda XL500R (82)
Honda XR500R (81-84)
Honda XL600R (83-87), XL600RC/RF (85)
Honda XL600RD/LD/RE/RF/RG/V-VH(Transalp)
Honda XR600R (85-89), XR600RH/RJ/RK
Honda CB750F/K/L (79)
Honda CBX1000 (79)
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline hahnda
  • lskdfhs;dljksa;
« Reply #11 on: September 23, 2005, 06:33:01 PM »
Also have a fork tube diameter list if anybody is interested. Also have both lists in Excel.
Kevin
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline Lumbee
    • My pics...
« Reply #12 on: September 23, 2005, 06:44:05 PM »
...drop me an E with the spreadsheets if ya don't mind...  marklocklear@gmail.com
stickitgraphic
« Reply #13 on: September 24, 2005, 12:53:48 AM »
Hey Thanks, I am looking foward to taking it all apart and making the changes I think look the best..
 As for the swingarm ???? Yes I went 6" over and the shocks are for a 750F they are about 1 1/2 longer than 750K shocks. As far as the angle I feel no diff in the ride but I also only weight around 150lbs. That may make a diff also...Thanks Kyler
stickitgraphic
« Reply #14 on: September 24, 2005, 12:56:07 AM »
As for the swingarm ? Yes I went 6" over and the shocks are for a 750F they are about 1 1/2 longer than 750K shocks. As far as the angle I feel no diff in the ride but I also only weight around 150lbs. That may make a diff also...Thanks Kyler
Offline Lumbee
    • My pics...
« Reply #15 on: September 24, 2005, 07:48:24 AM »
...so how did u legnthed the swingarm...just weld add length in?
stickitgraphic
« Reply #16 on: September 24, 2005, 09:38:55 AM »
Yes cut off where the swingarm pivot bolt goes, welded in to 6" plates. Then chromed for looks, I plan on making another one 10" over..Kyler
Offline Lumbee
    • My pics...
« Reply #17 on: September 24, 2005, 09:43:54 AM »
 ???  ...no sure I'm tracking...I understand you cut the swing arm off at the pivot bolt.  So at that point you had 3 peices, the pivot bolt section, and each side of the swingarm...then where did u weld plates in at?
stickitgraphic
« Reply #18 on: September 24, 2005, 09:56:55 AM »
No just two pices the arm and the pivot bolt sec., welded one plate to the arm sec. and the pivot bolt sec to the other end. Same on the other side, then filled the sides in with a small sec. of steal. They arm took 100% weld. I will try to get some more pics. so you can see it..
  I found this pic it is not mine but looks kinda like it....
Offline Lumbee
    • My pics...
« Reply #19 on: September 24, 2005, 10:05:40 AM »
...picture is worth a 1000 words!!!   thanx...
Offline Lumbee
    • My pics...
« Reply #20 on: September 24, 2005, 12:51:41 PM »
Ok stick...u inspired me...I just went out and chopped up an old swingarm I had.  Now, I think I can see how you welded two pieces...one on the top and bottom of the pivot.  What about between the two peices you added...did u weld a thin strip in there between the two?
stickitgraphic
« Reply #21 on: September 24, 2005, 01:15:52 PM »
  Yes I welded a strip on each side. Sorry no Pic of that.. Good luck glad I could help
stickitgraphic
« Reply #22 on: September 24, 2005, 01:20:30 PM »
Is that safe with plates alone?
My swingarm has steal all the way around. Not just plates the strecth is inclosed with 4 sections of steal and 100% welds. Thanks
el kabong
« Reply #23 on: September 24, 2005, 09:46:18 PM »
one suggestion might be the wheels off a 1979 cb750 LTD, that look like this:
http://cgi.ebay.com/ebaymotors/1979-Honda-CB750-LTD-NOS_W0QQitemZ4576315290QQcategoryZ80647QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
this is what they look like on a lowered/stretched cb650 LTD:
http://groups.msn.com/99mini/wwwwestendcycleca.msnw?action=ShowPhoto&PhotoID=355
stickitgraphic
« Reply #24 on: September 24, 2005, 09:55:18 PM »
Did you put any bracing in the box section you fabricated?
No bracing but used 1/4 steel kept a hair line between the pieces so the weld went a the way through. 100%
