Author Topic: '77 750 project  (Read 3266 times)
bmpaul02
'77 750 project
« on: October 30, 2008, 07:12:14 PM »
i have finally gotten started on my cafe project im tearing her down as we speak and working out bugs (blinkers wont work and suggestions would be great, also what does the thing in the lower picture do and can i get rid of it?
Offline DollarBill
Re: '77 750 project
« Reply #1 on: October 30, 2008, 08:22:52 PM »
That "thing" looks like whats left of the breather element but can't tell for sure.  I can't tell you for sure whether you can do without it or not...I would guess you could because I have seen some cafe racers with nothing in that area.
I am having some problems with my blinkers too and a lot of what I have read point to a bad ground, dirty connectors, and malfunctioning winkers.  It looks like it had sort of an Army feel to that bike...what are you planning to do with it?  The more I look at that flat green the more I like the possibilities....hmmmm.
Good luck with it!
1975 CB750F Project Yellow Jacket - CBR600rr Swinger GSXR 600 Forks
1955 BMW R25/3, 1966 Honda CA160, 1975 CB400f, 1975 CB550, 1976 CB550
bmpaul02
Re: '77 750 project
« Reply #2 on: October 30, 2008, 08:48:25 PM »
i do kinda like the old army look im going to look into that as i have ordered a new rust free tank so the color i have not really decided yet so, ill have to see this is my winter project
Offline XN
Re: '77 750 project
« Reply #3 on: October 31, 2008, 01:44:20 AM »
Its going to be hard to get any help on your turnsignals with out any info on what it does or doesn't do exactly along with are the bulbs good, where do you have power where you don't...
First check the fuse, make sure its good, the contacts are clean and you have power in and out of the fuse holder.
Second check all the bulbs and make sure they are good. The front will have two elements so make sure they are both good.
Now try it. What does it do? Did it blow the fuse? Flasher bad?...
Give us some feed back ;)
78 Honda CB750K
02 Yamaha V-star 650
02 Honda VTX 1800
Offline KB02
Re: '77 750 project
« Reply #4 on: October 31, 2008, 04:46:12 AM »
Yeah, that thing in the last pictures is called, I think, a Hoozy Whats-its...or Vapor Collector... one of the two. Hoses connect to it from the crankcase, breather box, and I think one other place, and it collects harmful vapors (condensation, evaporated oil...) before they make their way back into the environment and then recycles the gases back into the combustion process. There's usually a bit of a collection of nasty liquids inside the thing that needs to be cleaned out once in a while.
Can you do with out it? Yes. Will the tree hugging emissions people be happy with you? No.
Am I planning on getting rid of it with my bike? Yes.  ;) ;D ;D ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Johnny5
    • CB350F build thread
Re: '77 750 project
« Reply #5 on: October 31, 2008, 06:07:36 AM »
This is right. I think the another hose that connects to it is a hose from the bottom of the gas tank. I could be wrong but my 77 had this long hose under there and it stretch to where the collector once was. The PO must have taken it off.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
bmpaul02
Re: '77 750 project
« Reply #6 on: October 31, 2008, 07:36:30 AM »
fuses are good, when i turn on the blinker on either side, the clight on my clustercomes on and just stays on, on of the bulbs is dead wouldthat stop the otheres from working
Offline Johnny5
Re: '77 750 project
« Reply #7 on: October 31, 2008, 12:31:56 PM »
By the looks of the bike, most of the connections are probably soiled. I would go through each connection with some contact cleaner and see what happens after that.
1971 CB350
1973 CB350F
Offline KB02
Re: '77 750 project
« Reply #8 on: November 01, 2008, 06:38:55 AM »
I just re looked at the pictures and it looks like you have a DOHC fuel tank and an aftermarket seat.
Looks pretty good.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
bmpaul02
Re: '77 750 project
« Reply #9 on: November 01, 2008, 07:29:50 AM »
yes that is i believe an f tank i think, i like it i think ill keep it
bmpaul02
Re: '77 750 project
« Reply #10 on: November 01, 2008, 07:32:57 AM »
honda rear tails are single filament correct? My local bike shop told me the ones i had were not haonda tails but yamaha b/c they were duel filament
Offline KB02
Re: '77 750 project
« Reply #11 on: November 01, 2008, 04:51:54 PM »
That would make sense. Most state laws say that any rearward facing lights that are constantly on need to be red in color, so most factor bike of this era have only single strings bulbs with amber lenses.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
bmpaul02
Re: '77 750 project
« Reply #12 on: November 01, 2008, 06:45:03 PM »
i havent fully decided wheter or not to cafe this thing or not at the very least i will restore it to glory lol just need the free time being a full time student and worker owns all my time lol
can any one point me in the direction of a good factory seat
