Author Topic: Brake M/C leak fix?  (Read 590 times)
Offline jkot55
  • Wingman55
Brake M/C leak fix?
« on: October 30, 2008, 07:27:23 PM »
After riding I find some brake fluid on the underside of the brake lever.  The level does not seem to go down (must be very slight) and the brake lever is NOT spongy, seems firm.  Is this an indication the the M/C needs to be rebuilt?  If so, what is involved with that?  I have seen the kits on various sites.
Thank you
JK
When I ride my CB750 I'm a teenager again
Offline jhasewhite
  • my best vacation is your worst nightmare
Re: Brake M/C leak fix?
« Reply #1 on: October 30, 2008, 07:58:06 PM »
Brake fluid is nasty stuff, and will eat through paint within a few hours. I usually rebuild one the second I see fluid leaking. You can pick up a brake master cylinder rebuild kit with a new piston and seals for about $40. Just be sure to buy a quality set of expanding ring pliers (not at Kragen!) with long straight jaws to get the piston circlip out, as it can be a little tricky. After that it's a pretty straightforward job. Be sure to clean every passage very well, and try not to scratch the M/C bore. Re-assemble, bleed and ride. It should take about 1.5 hours to do correctly.
-j
slow and steady does nothing.
KingCustomCycles.com
« Reply #2 on: October 31, 2008, 04:49:56 AM »
You may just need a disassemble and clean.  I try that first before spending the $40 and have had good luck.  If you find anything torn or scratched, it is $40.00 time, or another used unit plus the 40.
Offline jkot55
  • Wingman55
« Reply #3 on: November 01, 2008, 09:20:45 PM »
That might be a good idea.  I just tore it down, cleaned, and reassembled it.  I refilled, bled and have pressure on the lever for overnight.  We'll see what happens.  Everything looked servicable, just a bit cruddy.
