Author Topic: F and K Front Calipers the Same?  (Read 2217 times)
Offline uwjberg
« on: November 01, 2008, 12:32:56 PM »
like the subject says.... would the caliper from a K model fit my F model? i'm looking to replace mine.
Offline voxonda
Re: F and K Front Calipers the Same?
« Reply #1 on: November 01, 2008, 12:59:38 PM »
No, it is definitely not the same, nor is it interchangeable.
Offline MrZxp
« Reply #2 on: November 01, 2008, 02:11:11 PM »
Which year/model bike are we talking about here?
75 & 76 F's had the same front calipers as the K's I believe.... 77 & 78 F's definitely do not.
Cheers, Phil
09 Boulevard M90
SOHC4 Member #3336
Offline uwjberg
« Reply #3 on: November 01, 2008, 02:12:07 PM »
i have a '75F, and i want to see if a front caliper from a '74K will fit.
Offline MrZxp
« Reply #4 on: November 01, 2008, 02:24:09 PM »
As far as I am aware, that should be a straight swap.
If not, I'm sure someone will chime in to put me right...  :D
Cheers, Phil
09 Boulevard M90
SOHC4 Member #3336
« Reply #5 on: November 01, 2008, 02:28:27 PM »
They may fit 75 or 76 BUT.. BUT... I think that they may have been unfinned style like on a CB 500 4.. if they are the  brakeline orientation is a bit different (comes out sideways [toward tire] in the middle)
« Last Edit: November 01, 2008, 09:38:32 PM by 754 »
« Reply #6 on: November 01, 2008, 03:24:57 PM »
Have you cross referenced the part numbers?? Same numbers mean they are the same.
Offline uwjberg
« Reply #7 on: November 01, 2008, 05:18:30 PM »
looks like different part numbers, but the schematics look very similar. hmmm....
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #8 on: November 02, 2008, 07:05:28 AM »
Cheers, Phil
The 75f is a k bike borrower in a big way. you should be fine.
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline voxonda
« Reply #9 on: November 02, 2008, 07:21:22 AM »
Cheers, Phil
Phil's right, year and model is important to know. When I think of F's it's the F2. But of course F1 is a K with another dress and jewelry.
« Reply #10 on: November 02, 2008, 07:42:42 PM »
Is there nobody on here that can say, wether 75 & 76 F model calipers are finned or not finned ?
I have a new Q,
a 75 F I believe has the reservoir and master cyl for the rear cast in one piece.. does 76 have the same ??
Just asking cuz I saw one similar but the MC was part plastic..
 just thinking it would be a nice looking MC to use to put disc on the rear of a CB 750.. matches the front..
Offline Clyde
« Reply #11 on: November 02, 2008, 09:15:33 PM »
The 75 and 76 F models use the same caliper and caliper arm, which is also the same as the K7/K8/750A(76 at least).
They are different to the K(69-76) caliper. Appearance wise- the F1 type use a hex head bolt from the outside, whereas the K0-K6 caliper use an allen head bolt, bolting in from the spokes side
The F/F1 caliper can be fitted to the 73-76K models, if you use the arm and bracket from the F/F1.
It cannot be fitted to the 69-72 (K0-2) model forks as they use quite different brackets, nor will it fit to the 69-76 caliper arm.
This a F/K7/K8 caliper
http://cgi.ebay.com/ebaymotors/Honda-CB750-F-K-A-Used-Front-Brake-Caliper-1975-78_W0QQitemZ150307323658QQihZ005QQcategoryZ35581QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This a K0-K6 (silver for K0, black for K1-K6) caliper with a 73-76 'T' mount as used on the K. Although this looks like an early K0 caliper, it is fitted with  a 73-76K 'T' mount. The 69-72 use the same caliper and arm, but they use the "C" bracket and hence mounting setup on the forks is different
http://cgi.ebay.com/ebaymotors/Honda-CB750-SOHC-Used-Front-Brake-Caliper-Assembly_W0QQitemZ160295493244QQihZ006QQcategoryZ35581QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Early K0-K2 'C' bracket.
http://cgi.ebay.com/ebaymotors/71-Honda-CB750-Brake-caliper-mount-CB-750-K1-69-70-72_W0QQitemZ290272136358QQihZ019QQcategoryZ35592QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
The rear MC is cast as one with the reservoir and is the same for the 75 and 76
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
« Reply #12 on: November 02, 2008, 09:30:15 PM »
 That is what I thought, the 75/76 F has a smooth caliper..
 However, I think the early  finned ones fit to the 73 & up bracket, there is a possibility that the swing bracket might be thicker where the caliper mounts, if that is the case, it may need shimming..
 so to answer the OP, yes a K caliper may fit, but will not be correct..
Offline uwjberg
« Reply #13 on: November 03, 2008, 08:14:12 AM »
ok - so then a 73-76K caliper will work on a 75-76F, providing the F caliper arm is used? and the K7/K8 are a direct bolt-on?
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #14 on: November 03, 2008, 10:14:56 AM »
No.
You have to use the "K" caliper arm, as it is 5/16"  thinner than the "F" arm where the caliper bolts up.
In short, keep the "K" parts together, and the "F" parts together, and things should be groovy.
The cb550 and 500 calipers will not work either, for they may look similar to the stock F1 caliper, but the bolt spacing is entirely different.
Hope this helps!
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline uwjberg
« Reply #15 on: November 03, 2008, 11:57:35 AM »
ok - i see. that makes more sense when you put it like that.
