Author Topic: The "Hondaman" Transistorized Ignition  (Read 6054 times)
Offline Mossy21
  • It takes "Time" to be a Classic..........
« on: November 02, 2008, 07:50:39 AM »
I have a CB750 that I want to put this system on.  Is there a diagram or link to how it's done ? And what I'll need ?     Thanks in advance  :)    Mossy
If I can't see the Engine I can't see the point.......
Offline kghost
Re: The "Hondaman" Transistorized Ignition
« Reply #1 on: November 02, 2008, 10:12:14 AM »
Its really simple. Basically plug in 4 wires and power. The unit comes with all the instructions and recommendations.
Have you PM'd Hondaman? I would recommend asking him any questions you have.
I really recommend the unit. Its really slick and cool.
Stranger in a strange land
Offline StrongPerf
« Reply #2 on: November 05, 2008, 09:16:50 AM »
I've done it on my 550 and it worked out well. There's a few more than 4 wires. You have to run a green wire down to the points. Then you basically take your wires going to the coils and go in to his box and then wires from his box to the coils. A tap into coil power and a ground and your done. He also shows an option for full power for max rpm performance which uses a big wire and bypases the kill switch. I plan to use a relay to do this and have my kill switch trigger the relay. I haven't done this yet but still it has smoothed out my bike plenty. I like the piece and his service is superior to anything out there. Give him a PM shout. Later!
Offline bert96
  • past ride
« Reply #3 on: November 07, 2008, 05:48:02 PM »
Here's the diagram,
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
