Okay the two front mounting bolts are 1 15/16" long on the timing side, and 3 1/8" long on the stator side.
The front bottom bolt is 10mm by 12 1/4" long (310mm roughly).
The rear bottom bolt (also holds the foot pegs) is 12mm by 13 3/4" long (350mm roughly).
The top rear bolt is 10mm by 11 1/16" long (280mm roughly).
Hope this helps.
