Well it was getting close to warm enough to paint and I had an
I had primed the rims 6 days ago, so I took them to the garage to hit them with gloss black rustoleum. It went on nice, so i came back the next day to spray the frame in the garage with primer and the can was faulty - kept leaking around the nozzle and pooling on the top of the can - then spitting big heavy droplets all over, and when I would shake the can it would catapult across the garage onto things that were not covered with painters cloth. Including my recently painted rims.
So I wiped it off with a dab of thinner on a paper towel, and it burned right through to primer and some metal. #$%*.
Started over with another coat of primer, (should've sanded afterwards, but just didn't feel like it.) Shot the black, then did 2 light coats of the Duplicolor Wheel and Rim Clear Coat over top then one "medium wet coat" as directed. I might not even sand and buff them, as I'm so happy with their result. So sorry for the camera phone shots.
In the drying times I went inside to work on my swingarm - I had forgotted to bring it out to put with in the tiny paint booth, and after seeing Phaedrus' Chromed swingarm, I said HELL NO I'M POLISHING! It came up nice, and I might hit it with an adhesion promoter then the same wheel clear coat (it has this somewhat reflective quality to it that makes me think the light will pick it up great at night.
[youtube=425,350]http://www.youtube.com/watch?v=z3s4nMR0yxk[/youtube]
Tal-Strip is the bomb. Ten minutes! Wash it off and hit the spots you missed, and done.
After the wire wheel.
After the GREEN TRIPOLI STEEL POLISHING COMPOUND.
Paint booth in place with a space heater to get it to 60 degrees! That was definitely the problem last time - needed to cure!
Dirty grimey greasy engine. Yuck.
Frame after the Rustoleum Gloss black - I don't think I'd put the wheel and rim clear on at this point.
Finally getting this engine clean!
I used cheap old engine degreaser, which does have an oily film to it. What would you all recommend I prep with? Brake cleaner? Dish soap? I'd really like some quick help on this as I might build a bracket and paint this baby today!
Future plans on the project block:
Lace Wheels
Mount tires.
Mount rims/swingarm.
Paint Engine, Kickstand, Gauges.
Replace fork seals.
Complete rolling chassis.
Dent tank
Prime Tank
Strip seat
Mold seat pan/cafe hump.
Mold sidecovers (From whoknowswhat)
Have clipons made. (will keep you posted on this one!)
Mount Engine
Mount carbs/battery/airbox
Mount controls.
Fab seat cushion. (same time as VFR seat rebuild.)
Figure out brake light.
Send seat, headlight bucket, tank and sidecovers to Dad for paint. (quality unmatched for a self-taught!)
Polish stator cover.
Figure out exhaust (picked up beautiful stock 550F headers and just need a muffler!)
Reassemble
Tune
Ride.
