I though I'd posted this last night, but I can't find the thread anywhere, so I obviously did something wrong
So the trusty, and much abused, H100 has finally been stripped down to its component parts for a long awaited, and well deserved, thorough clean and overhaul. Apart from requiring a new piston, a hone of the barrel, and a gasket set, the bike is mechanically in far better fettle than I expected
However, the wiring loom (especially the plug connectors) has definitely seen better days, and since the original electrics were never really up to that much anyway, I thought I would investigate the possibilities of upgrading to 12V.
Whilst the existing alternator should be OK, I suspect I will need different voltage regulator , and probably a CDI unit? Items from a later 12V 4 stroke CG125 should be more than adequate I would have thought, but what I’m not sure of is what alterations will be required (mainly with the charging circuit, I suspect?) when I build the new loom.
Do I build a straight replica of the existing 6V loom? Or do I look at incorporating aspects of that from the CG125?
All advice, comment, and/or assistance will be gratefully accepted
