Author Topic: Tip to re-use those float bowl gasket o-rings  (Read 8293 times)
Offline StrongPerf
« on: November 05, 2008, 09:19:55 AM »
So those o-rings swell up from the gas an you pull the bowl off and they are too big. I read hear you have to get new ones. Nonsense! If you wait a day or 2 they will shrink back up but who has time for that. I pre-heated my oven to 200 degrees F. I put them in an aluminum pie pan and place them in the oven for 10 minutes. Done! When they are real bad, I've done this then put them in the freezer for 5-10 minutes after the oven. Done! Re-used many times...
Offline tortelvis
Re: Tip to re-use those float bowl gasket o-rings
« Reply #1 on: November 06, 2008, 07:59:03 AM »
Thanks for the tip! Always good to learn new tricks.
Offline void909
« Reply #2 on: November 10, 2008, 11:11:45 PM »
great tip thanx!
knock with no answer
Offline torrinh
  • If you don't ride in the rain, you don't ride.
« Reply #3 on: November 21, 2008, 07:57:43 PM »
should you rub them with a little motor oil so they don't crack?
1983 Kawasaki GPZ 750
1978 Honda CB750K w/ 1976 CB750F1 motor
1979 Suzuki GS550L
Offline Venturous
  • CB750 Hack Pilot
    • eMotorcycling
« Reply #4 on: November 21, 2008, 08:19:05 PM »
Which O rings are you referring to? I just put my bowl back on and don't recall any o-rings in there.. Not
a good sign!  :o
eMotorcycling
'72 CB750-K1 w/Spirit Eagle sidecar
'02 Royal Star Midnight Venture
Offline heffay
« Reply #5 on: November 21, 2008, 11:13:52 PM »
F waiting  ;D
Offline StrongPerf
« Reply #6 on: December 01, 2008, 09:03:01 AM »
I didn't rub mine with oil and they didn't crack.
Pic shows the oring I'm talking about.
sprocket
« Reply #7 on: December 14, 2008, 11:41:21 PM »
Thanks, Need to check the floats next weekend, this will save me a few dollars and time picking up new gaskets. be careful what you put in your oven, You shouldn't mix the food stuff with the bike stuff,  I have a rather large toaster oven I use for this kind of thing.
Offline 1timduke
  • '75 CB550
« Reply #8 on: December 16, 2008, 05:34:52 PM »
Wish I'd known about that 6 months ago :P   Great Tip!!!   -Tim
The only thing I miss about the South is Waffle House!
Offline Kalamazoo
« Reply #9 on: December 19, 2008, 11:19:46 AM »
Great tip!
I'll be useing it in about a week  :D
M.R.
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #10 on: April 03, 2009, 09:05:34 AM »
mine have been off for a couple months and they still dont fit. maybe ill try the oven thing though. i actually bought a set of the rubber o-rings, and they are just as much of a pain in the @$$ to fit in
