Author Topic: help! removing stuck fork caps....  (Read 1070 times)
Offline crowned
« on: November 08, 2008, 07:17:04 AM »
The title says it all really, I'm trying to get some fork caps off my 74 cb550, and they are on there pretty good.  I loosened the clamp that clamps right there, put some liquid wrench on them, then used an impact driver....
what else is there!  any ideas would be much appreciated.
Re: help! removing stuck fork caps....
« Reply #1 on: November 08, 2008, 08:30:07 AM »
why loosen the clamp bolts, the cap is inside the fork tube.. make sure you have a good fitting socket..
Offline Alan F.
« Reply #2 on: November 08, 2008, 11:00:43 AM »
This is why I keep an extra triple tree around, I clamp the tube in the tree and lay it down sideways on a thick carpet, then use my foot to push the wrench to break it loose.  Reassemble with a little anti-sieze for next time.
Offline heffay
« Reply #3 on: November 08, 2008, 11:26:19 AM »
excellent tip
Offline Alan F.
« Reply #4 on: November 08, 2008, 12:46:58 PM »
excellent tip
Thank you very much!
« Reply #5 on: November 08, 2008, 08:58:44 PM »
..or just clamp a lower triple tree in the vise (softjaws on the stem).. a bit easier..
