Author Topic: dont use hydrochloric acid...  (Read 1111 times)
Offline tygrant
« on: November 08, 2008, 10:23:56 AM »
im kreeming my tank today and before using the rust removoer i figured because my tank was soooo rusted inside id use a litle HC acid first, it was only in there for a about 5 mins took the rust out... and the metal so now im letting the etch sit in there and its driping out of like 4 holes in the bottom of the tank.   ugh god i hate when i do shti cuz i think i know what im doing but i really dont. at least it will be clean in there ha
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline Soos
Re: dont use hydrochloric acid...
« Reply #1 on: November 08, 2008, 10:31:12 AM »
leaking....
not a good sign.
I hope they are pinholes, and the kreem adheres well enough to seal them!!
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
« Reply #2 on: November 08, 2008, 10:50:10 AM »
Find a radiator repair shop that will solder it for you. I had a local guy do a large solder job and seal with Redcote a CT90 tank for $80.00. Couldn't do it myself for that.
Offline heffay
« Reply #3 on: November 08, 2008, 10:53:37 AM »
actually, i don't think that you did a disservice to your tank... it was only a matter of time before the tank got to that point, and i doubt 5 minutes of HC acid could do that sort of damage to a tank not already in need of repair.
your tank WILL be better than it would have been... there, glass is half full.   ;)
Offline tygrant
« Reply #4 on: November 08, 2008, 01:12:39 PM »
thanks for the word of encouragement. i think i will be fine, the tank was in terrible shape. when i got it had jbweld all over one side and the bottom so i knew it was it bad shape, i used lots of bondo and sanding and smoothed it so that you cant even tell that one side of the tank is 1/4 thicker than the other. its just pin holes dripping and they run to the back of the tank and drip off so i put a funnel and the tank prep bottle there so every 20 mins i go out and top the tank off again. ha its kinda hokey lookin but its working.   HC def does the trick it was in for 5 mins and it was clean. there was smoke coming out of the fill hole and thas when i said hmm i shouldnt leave this in here long. nother hour or so and im guna kreem it. wish me luck with this stuff
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline heffay
« Reply #5 on: November 08, 2008, 01:25:11 PM »
ok, the trick to these things is you're either gonna stay awake for a while  ;)
or you're gonna come back to it... either is fine, but make up your mind.
good luck.
eldar
« Reply #6 on: November 08, 2008, 02:31:48 PM »
I would never line a tank with holes in it. I would get the holes fixed first. Liners just do not create a permanent fix as far as I am concerned. Not against holes anyways.
Offline ghost
  • what do you mean i can't do that? I just did it didn't i
  • it's all about the last inch baby(even when it's metric)
« Reply #7 on: November 08, 2008, 02:56:47 PM »
sounds like it's about time to break out some sheet metal and the good old body hammers and fab up a new tank. maybe that's just me though
1980 cb650c first bike i owned now the wife's ride.           1982 xv920j virago, bike i learned to ride on rescued it from a 13 year coma (sitting in the shed) now she runs beautifully and rides like a dream.
Offline tygrant
« Reply #8 on: November 08, 2008, 06:44:16 PM »
well i kreemed it and a drop or two of the liner came out of the holes but it stoped quickly. i think once it dries il put some jb weld over the spots where the holes are, this isnt going to be a show bike and its on the bottom of the tank. if it doesnt end up working il look for a new tank but lets hope it does. this bike is taking over my life... every spare minutes i have im doing something to it
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #9 on: November 08, 2008, 09:22:52 PM »
I don't think I would even mess with a tank with a bunch of holes in the bottom?  Seems like they are on feeBay cheap enough, maybe look around for a decent replacement? They go pretty cheap if you don't care about it having the stock paint still in great shape.
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
