Author Topic: 1978 cb750 carb adj.  (Read 12664 times)
Offline grwmotocycles
« on: November 08, 2008, 10:44:47 AM »
Just fired up the 750 from a year resto.  runs good better with a little choke and will not hold an idle, have to flutter to keep running.  Any secrets to adjust carb. before I go through the manual.
            thanks Geno
Re: 1978 cb750 carb adj.
« Reply #1 on: November 08, 2008, 11:39:09 AM »
The secret is to pull the idle jets for cleaning.
Offline joeb
« Reply #2 on: November 09, 2008, 06:08:16 AM »
I secound that.
Offline cafe2be
« Reply #3 on: November 09, 2008, 06:41:42 AM »
i have the same problem. I am running a 77 750f with pods and a pipe. I was told i need to raise the needle height
Offline Bill K
  • 78 750k
« Reply #4 on: November 09, 2008, 07:15:06 AM »
I can third that. PULLING and cleaning those idle jets made a bigger difference in the way my bike than everything else combined.
Offline shoemanII
  • just another bike nut
« Reply #5 on: November 09, 2008, 09:28:50 AM »
after the idle jets are pulled for cleaning, how are the internal passageways/slow speed circuits cleaned.  carb clean sprayed into the jet side, or something?  i'd like to avoid separating the individual carbs for soaking if possible.  bike takes a 3-4miles to warm up then runs great.  just trying to improve this a little.  thanks,
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
Sd455
« Reply #6 on: November 09, 2008, 09:43:46 AM »
My 77 F takes forever to warm up, I think they're cold blooded. I took them apart soaked them in Chem tool (be very carefull with that) sprayed them with carb cleaner and blew them out. Then synced them. Did you take out the pressed in jets?
Oh, and it wouldn't run right w/o the air box on. Seemed too lean.
Offline shoemanII
« Reply #7 on: November 09, 2008, 10:22:43 AM »
stock pipes and airbox, K engine.  took out and checked the idle jets (were clean).  no air compressor, maybe a can of compressed air for computers?
bobp
'72 dt2
« Reply #8 on: November 09, 2008, 04:36:38 PM »
Thanks for the heads up, I will clean and let you know the results.
alis
« Reply #9 on: November 09, 2008, 05:42:45 PM »
Is the idle jet the same as the slow jet?  Im having the same problem on my 78 750k and am suspecting thats what it is?  What is the name that is used in the manual?
« Reply #10 on: November 15, 2008, 09:43:47 AM »
dissembled the carbs. cleaned all jets.  Engine still will not idle under 2/2200 rpm.  The center pipes (both ) are discoloring.  checked the plugs and they are very white (Lean) on both center cylinders.  Restarted the bike and used a piece of cardboard to cover each carb. one at a time to see the reaction and the two outer carbs. when slightly covered will raise Rpm I am sure it is pulling more fuel.  The two center carbs. when covered will not raise rpm just push fuel out of the intake and soak the cover.  ?  Idle circuits still plugged??? Need some other thoughts on this matter.  Thanks Geno
« Reply #11 on: November 15, 2008, 11:41:25 AM »
When checking the idle/slow/pilot circuits you have to make sure the passageway in the carbs are open between four exit hole from the carb body.
1. The idle/slow/pilot jet
2. The  idle/slow/pilot AIR jet
3. the adjust screw recepacle
4. the exit hole into the carb throat.
You also MUST be able to see light through the  idle/slow/pilot jet itself.
« Reply #12 on: November 15, 2008, 02:41:21 PM »
TwoTired;  I may have many questions for you.  I will check the items you said,  be patient I am not real familiar with these carbs,    Thanks Geno
« Reply #13 on: November 15, 2008, 04:13:52 PM »
I have the same bike and it took me three tries to get them right. I finally rodded out everything with a high E guitar string and strands of copper wire. You can also be running lean due to hardened carb boots. These bikes are a bit cold blooded at startup, but not to your extent.
« Reply #14 on: November 15, 2008, 06:50:43 PM »
I hear Ya! Cold blooded is not even the word for it.  I am sure I will figure it out with a little time.  Just wanted to be on the right track
eldar
« Reply #15 on: November 15, 2008, 07:23:10 PM »
Maybe this winter I will do a write up for these carbs. They are actually pretty simple really. Cleanliness is the top priority.
Offline medic09
« Reply #16 on: November 15, 2008, 09:48:27 PM »
There are several past threads on this, as well.  If you search, they may help.  Or at least entertain you.  ::)
Cafe2Be, if you have the 77-78 carbs, there is no adjustment for needle height like the earlier carbs have.
Eldar, that's a great idea.  Get to work!  ;)
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
eldar
« Reply #17 on: November 15, 2008, 10:39:42 PM »
Actually the 77 does have needle height adjustment.
« Reply #18 on: November 16, 2008, 06:01:23 AM »
Why wait its Snowing in OHIO!!!
Thanks Geno
eldar
« Reply #19 on: November 16, 2008, 08:32:08 AM »
I have to winterize my house first! AND clean up my workbench! ;D
upperlake04
« Reply #20 on: November 16, 2008, 08:47:40 AM »
 You're wiggling Eldar  ;D ;)
Offline medic09
« Reply #21 on: November 16, 2008, 10:06:44 AM »
My bad!  I thought the 77 and 78 carbs are identical?  ... ???
Mordechai
'78 CB750K
Santa Fe, NM
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #22 on: November 16, 2008, 03:15:11 PM »
um, 78's have adjustable needles as well, you just have to separate the carbs fully to do it.
Offline medic09
« Reply #23 on: November 16, 2008, 06:21:11 PM »
I have stripped and rebuilt 78 carbs twice.  Those needle do not have clips.  They're fixed on my bike.  Of that, I am certain.
Mordechai
'78 CB750K
Santa Fe, NM
Offline Porscheguy912
  • I'm a Big Shot Ninja.
  • It's MR. Moustache To you SIR!
« Reply #24 on: November 16, 2008, 10:01:52 PM »
+1 on that. No clips on 78 carbs. 100% sure.
Unless someone rebuilt them before and used the wrong kit.
Current: 1978 CB750F3
Past: 1974 CB550K
